3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Reading Switches with ATtiny2313
Step 8Using The switch/case Construct
The final step is "just software": As promised, we'll implement the switch/case construct. Although this example only shows two alternate actions, it should be very clear how to use this construct to select one of several alternate code sections. In operation, this program monitors the switches and if there is a change, it will beep the appropriate number if it is odd ; it'll blink if the number is even. It does nothing unless a switch changes.
To run this code, create a new directory (call it Switch if you like) and download the following C code file and makefile into it. Rename Makefile3.txt to just Makefile. Using WinAVR, compile the program and load it into your Attiny2313.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:doctek
