Readly Available Mini Lethal Blow Gun
Introduction: Readly Available Mini Lethal Blow Gun
  ::::::::: CAUTION :::::::::: THIS IS A LETHAL PROJECTILE, I RECOMMEND ADULT SUPERVISION,   OR COMMON SENSE.        most of you may even be able to make this out of just what's  in your reach right now..  U  Need ::: DRINKING  STRAW ,,  ROUGHLY  1/2"  IN.  OF YOUR SHOE LACE,,,   ONE SEWING NEEDLE,,,        it is quite accurate will travel into door trim and solid doors very nicely   :)          OK FIRST GET A SHOE STRING THAT STILL HAS A DECENT PLASTIC COATED END, ( sorry I don't know the proper name for it) CUT IT IN HALF KEEP PLASTIC INTACT, THEN  CAREFULLY  CUT HALF OF  THE PLASTIC COATING OFF PEEL IT AWAY KEEPING STRING INTACT,, GENTLY FRILL THE STRING , FLUFF IT UP  ,  THEN INSERT YOUR SEWING NEEDLE FROM THE FRILLED (OR BACK OF YOUR NOW ARROW) INN DONT PUSH ALL THE WAY THROUGH.  LOAD INTO STRAW AND A BURST OF AIR (BLOW) AND HAVE FUNN.      THANKS FOR LOOKING...
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
    Good job on this but I really don't think you should of posted it here. I have a feeling some stupid kid will try to use this on there class mates or teacher. Not trying to make you mad or start anything it's just a bad idea that bad people may use on others
    Aglet that is the plastic end on a shoelace just so you know
