Real Man's Toothbrush
Introduction: Real Man's Toothbrush
A high powered redneck tooth brush (don't scrub a hole in your teeth)
YOU SHOULD NOT PUT THIS IN YOUR MOUTH (I was told to say this, if your stupid enough to put this in your mouth, all I can say is have fun explaining that to your dentist)
Step 1: Supplies
you will need:
tooth brush you don't mind wasting
nail (or other thin peice of metal for the shaft
wire clippers (for cutting toothbrush)
Dremel tool (or other rotary cutter)
Step 2: Chop
go ahead and cut the head off the tooth brush
Step 3: Melt
use your lighter and heat the head of the nail, once good and hot push it into the middle of the toothbrush and hold it straight until it cools some and will stay.
Step 4: Glue It Good
mix up some weld and apply liberally, let it dry and present it to some one who has a dremel tool and loves gag gifts.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Am I the only one to have ever used a dremel to trim my finger-nails?
    REAL men use the metal brush bit
    Real men use angle grinders for teeth and bandsaws for nails... :P
    My orthodontist uses a dremel for working with the metal pieces, so when he took it out, I started freaking out!
    i only use the stone bit on my teeth
    I wasn't aware that rednecks brushed their teeth. silly me...
    I didn't know they had any to brush. :-D
    Dont you think thats gettin a bit personal? Jist cus i only has a gold tooth left dont mean that is gonna not brush it. that thar gold is spensive.
    And, you need to be politically correct. I aint no redneck, I is a appalachian american.
