3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Real Sourdough Bread
There is a lot of confusion about what sourdough bread is. Is it bread with a sour taste? Do they only make it in San Francisco? What makes it so different?
Sourdough bread is bread that is leavened using a sourdough culture containing wild yeasts and bacteria. The yeast that can be bought in small packages and jars at the store is commercial yeast . It is one strain of yeast, raised because it is really great for making bread quickly consistently. A sourdough culture will probably contain many different strains of yeast, and several types of bacteria. While an envelope of commercial yeast is innumerable copies of one organism, a sourdough culture is a diverse ecosystem. Because of this, sourdough breads have a more complex flavor and texture than breads made with commercially available yeast.
So where does the "sour" part of sourdough come from? While yeast produce carbon dioxide and alcohol, the bacteria in a sourdough culture produce lactic acid. This give some sourdough breads their distinctive tangy taste. The increased acidity and other compounds produced by the bacteria  make sourdough breads more resistant to mold and staling than other artisan breads.
Although these bacteria can make the bread tangy,  not all sourdough is noticeably tangy. It depends on what bacteria are in the culture being used. However, there are methods that can create the sour flavor that some people enjoy in their bread.
Making true sourdough bread is more difficult, and more time consuming than using instant yeast. That having been said; sourdough creates loaves of bread that have a flavor that can't be matched by breads made using commercial yeast.
It is a common misconception that sourdough bread can be produced using a commercial yeast that is allowed to develop in a batter overnight. This is called a preferment, poolish , or biga . This technique can make really great breads, but it isn't true sourdough and tastes very different. Here I present sourdough bread and describe the techniques used to create it.
Step 1Assemble Ingredients
First, assemble the ingredients.
A real sourdough loaf is surprisingly simple ingredient-wise. The quality comes from the technique. Of course, having good quality ingredients will help too.
Ingredients
Unbleached Bread Flour
Rye Flour
Water
Salt
Rye Starter
Flours
Bread Flour - This flour is different from regular all-purpose flour in two ways. The first is that it is milled from different wheat, often harvested at a different time of the year. This wheat contains more of the compounds that will form gluten in your bread. Gluten is what makes dough stretchy and bread chewy. The second way bread flour is different is it often contains malt powder. This encourages yeast growth. Not all bread flour will contain this but most commercially-available bread flours in North America have it.
Rye Flour - This is a whole grain flour. It adds complex flavor to breads and is used to feed the starter in this recipe. Rye flour will not form gluten on its own. The more rye flour is in a bread, the more difficult it will be to form gluten while kneading.
Whole Wheat Flour-Not mentioned on the list. It is strictly optional. This is a whole grain, more flavorful flour. Some people find it bitter. Usually when I am making this bread about two cups of what I have listed here are whole wheat flour, I enjoy the flavor. It absorbs water more slowly than white flour.
I recommend practicing the recipe a few times with mostly white flour and then incorporating more whole wheat or rye flour into the recipe.
Water
A lot of people say it is important to use spring water or filtered water or some other water, that chlorinated water will kill your yeast.  I use tap water (yes it's lightly chlorinated) as do most great bakeries I know to no ill effect. If your tap water smells like a swimming pool it is probably better to use spring water or filtered water. I've never had a problem with it.
Salt
Salt is extremely important in bread. Do not omit salt based on the reasoning that it will be healthier. Not that much salt goes into bread. Salt balances the flavor of bread very nicely, if you don't add it your bread will taste strange. Salt also helps in regulating yeast growth. If you don't use salt the yeast may develop inconsistently.
As for what type of salt, I use plain free-flowing salt. Sea salt, kosher salt, Himalayan pink salt; all fine-it won't make a difference in how your bread tastes. I would save the good salt for some other application. If you do use some other type of salt, be aware that 1 Tablespoon of plain salt does not equal 1 Tablespoon of kosher salt. The larger grains change the volume. If you are going to play around with salt types use a scale to make sure it is the same amount.
Rye Starter
This contains nothing but rye flour and water. This is all wild yeast, no stuff from the jar/packet. Don't ever add salt, sugar, pineapple juice, or anything else but flour and water to this. If you wanted, you could easily use your wheat starter for this recipe; it should work but the fermentation times may be slightly different based upon the starter you use.
18 comments
Mar 22, 2012. 2:48 AMfancy4baking says:
Hello there,
I see the ingredients but i don't see their respective amounts!!
Can you please tell us how much of each ingredient we need to add?!!
Thanks,
Mike :)
Jun 5, 2011. 6:29 AMbowow0807 says:
what would i do if my dough is really runny as in it wont hold its shape? should i add more flour? because when ever i make sourdough it turns very runny even if my water is 65%. and can anyone explain why it does that?
Jul 3, 2011. 10:01 PMbowow0807 says:
well i guess ill make it again and see what happens, because i make my breads by feel, i feel when there is too much water or too little flour and salt, and also i test if my kneading is done that when i poke it if it springs back the way i like then i consider it done. or it could be my starter, my starter is a whole wheat natural starter i wanted to use rye but its really expensive around 6-7 bucks a kilo so i settled for whole wheat, i replaced all the rye in the recipe with whole wheat and followed the recipe as usual
Jul 26, 2011. 3:33 AMbowow0807 says:
and by the way i forgot to mention this but if i remember correctly the acidity in the starter especially tenacious starters(like mine) the acidity can break down the gluten strands that is why and right now i just made this recipe again after an hour of the first fermentation of my nicely kneaded dough it became very soft and quite runny and so i had to knead it again -__- and i don't know why (note i used 1 cup of whole wheat and 7 cups of bread flour) i really think that it is my starter because when i first started it, it came to life on the 3 day!! so i think i have really tenacious bacteria in there.
Jul 24, 2011. 8:08 AMbowow0807 says:
thanks! and im not in the USA so anywhere you can suggest is out of the question and also have you seen this kneading technique?
http://www.youtube.com/watch?v=PvdtUR-XTG0
it is very useful for very wet dough so as to decrease excess flour additions this is actually what i used when i made a 80% hydration dough its really good so try it!
Nov 8, 2011. 11:55 AMbowow0807 says:
well my baking has improved especially my shaping and scoring techniques. but unfortunately my starter got orange and moldy on me and my attempts to make a new one are going bad but it just might be i'm trying a stiff starter maybe i'll stick to batter starters loaves are better all i'm missing is a nice big oven. i only have a oven toaster right now and it can barely take a 400g flour bread with good oven spring without burning the top.
May 8, 2011. 7:37 PMMarknKS says:
Sunset Cookbook is a treasure trove of delightful info about Cal cooking and history.
It says that Le Boudin's starter, started and kept alive since 1850 has a species of Lactobacillis, unlike any other previously characterized, and hence named L. sanfrancensis by a UC Davis microbiologist who analyzed the starter.
They recommend, for people living anywhere who want to get a reliable starter, to mix 3 tbspns of live-culture (gelatin-free) plain yogurt, a cup of non-fat or low-fat milk, and a cup of flour. Keep at 80-90 degrees in a sealed bowl. I use an incandescent lamp, positioned above the bowl to maintain temp.
They say 2-5 days, develops bubbles, and clear liquid on top, indicating acidification and coagulation of milk proteins. The milk contains lactose, which the bacteria convert first to lactic acid, and then the lactic acid to acetic acid.
I like tangy bread, so I let mine go (with periodic stirring) for 7 days. Waay more sour than the original yogurt!
Harold McGee also gives passing reference to bacteria. It's not just yeast that is at work here for true sourdough.
Anyway, then the recipe calls for mixing in flour, salt, sugar and regular active-dry yeast, to get your rise. It calls for 15 minutes of kneading, then 2-3 hours of proofing, one punchdown, a short re-rise, and 350 degree baking for 35 minutes, with some water spraying a few times to get a thick crunchy crust. (I prefer 500 on a preheated bakestone for 10 minutes.)
The Lactobacillis, fed on a lactose substrate that it can acidify makes a SF-sourdough-quality tang. It's a recipe worth giving a try, and playing with to suit your tastes.
If you are a cookbook collector Sunset Cookbook is a beauty. If you want to try West Coast cuisine, it has great stories, and awesome recipes from fine restaurant chefs to home-cook inventions.
Mar 3, 2011. 11:59 AMJeanette56 says:
A good alternate for Whole Wheat flour is King Arthur "White" Whole Wheat flour. It is a whole grain but not as strong tasting or as 'heavy' as regular whole wheat. We have been using it for pretty much everything and it is a wonderful alternative to traditional whole wheat flour.
Here is the link to WWW flour if you are not familiar with it. Most main stream groceries should carry it as well quite a few health food type stores.
http://www.kingarthurflour.com/shop/items/king-arthur-white-whole-wheat-flour-5-lb
Feb 2, 2011. 1:03 PMDave55555 says:
Wow! Excellent instructions (and I find most recipes very hard to understand!!). I appreciated the conversational style (and the background info about salt). Thanks again. ... dave in austin, texas
Jan 31, 2011. 3:30 PMtycobb48 says:
Hi - looks real good - and well written! I'm just a little confused on the rye starter. You say it's just rye flour and water, plus the need to feed it...How much flour to water, w/ what do i feed it, how often, and do i leave it out or in the fridge? Thanks!
Jan 31, 2011. 3:27 PMtchitwood says:
Great Instructable! Very informative. :) Makes me crave some good sourdough!
Jan 30, 2011. 5:54 PMjen7714 says:
Very descriptive. Makes me want to try to make sourdough bread again. :) Great ible!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:RebelWithoutASauce
