3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Real-time Web Based Household Power Usage Monitor
This Instructable details a real-time web based household power usage monitor. The end result is a live chart in a web page that updates every 10 seconds with the instantaneous power usage for my entire house. The electrical current is measured on the main lines entering my home with AC clamps. The signal is then conditioned with a simple circuit and monitored by an ioBridge module. The ioBridge module takes care of feeding the data to the internet without the need for me to host a power hungry home web server. By using ioBridge widgets with a few JavaScript API calls on my web page, I am able to chart the data with Google Charts as it is measured and make kilowatt-hour calculations in real-time.
Step 1AC Measurement
AC Measurement
There are a few ways to measure electrical power. The way I chose might not be the most accurate but it achieves two of the main criteria for this project. It had to be cheap and I didn't want to screw with my home electrical wiring to make it work. I did not want make an electrical connection with main power wires. The idea of interfacing directly to 220v makes me nervous. I could have used a Kill-A-Watt but it is only good for one outlet. Plus there is no way to get at the actual data, basically can just look at it on the LCD display. I've also seen commercial power meters for this kind of thing. Since those meters can cost over $1000, I didn't want to go that route either.
For this project, I used an AC clamp. With an AC clamp, it is possible to measure the current traveling through a wire without physically touching it. Basically it is a simple transformer where the wire of interest acts as the primary coil and the AC clamp is the secondary coil. Most AC clamps are integrated into a multi-meter. I used a stand-alone type for my project. It outputs 10mV per ampere and is intended to be connected to a multi-meter. All you do is multiply the voltage reading by 100 to get the current in the wire. These can be found for $20 or less on Ebay. Mine were made by Steren, model MUL-285. The great thing about using an AC clamp is that I was able to do all of my prototyping without ever turning the power off.
89 comments
1-40 of 89next »
Jan 29, 2009. 1:15 PMrkincaid says:
Would it be possible to just measure the neutral wire and only use one ac clamp?
Feb 10, 2009. 6:07 PMham4fun says:
No, because dryers or other 220V equipment won't pass any current through the neutral wire.
May 24, 2009. 9:40 AMlegless says:
Huh? What?
Sep 3, 2010. 1:56 PMthreadabort says:
Dryers and 220V equipment use the difference between the two others wires. The neutral wire is at 0v. So, let's say you want 240v. 60 times a second you will have a configuration that looks like this: start of cycle: black wire - +120v Red Wire -120v half cycle: black wire -120v Red Wire +120v As you can see, you would get 240v by using the black and red wire since they are 240v apart at their peaks (AC). The rest of the house uses either the black and neutral wire or the red and neutral wire. And that is why they usually say your house is on two different phases.
Jan 14, 2012. 10:38 PMjenkinch says:
Is this why you can just measure the red and black wire, add that up and get your energy consumption? I figured you would have to account for the the voltage going thought the neutral separately otherwise the 240v would be accounted for twice.
Sep 18, 2010. 3:12 PMlegless says:
You have a weird way of wiring stuff in your country. You want to try testing the idea that there is no current in a neutral wire from any appliance in my country by grabbing it and you will likely have a whole new hairstyle if you live. Of course all of our mains equipment runs off 220V-240V here. Houses here are normally just supplied by a single phase coming from a supply in the street that is multiple phases. If you want power from a second phase for some reason is taken from another in the street supply. You could also get 415V 3-phase power connected if required here.
Jan 1, 2012. 10:37 AMlrdforster says:
I just come across your instructable and had a look. I found both it and the comments interesting reading. Power factor is interesting and needs a simple measuring solution.
Many years ago when I was an apprentice I recall seeing an analouge Power meter which compencated for power factor. As I recall it had a voltage coil and Current coil combined in such a way they gave a Power reading.
The Idea was as the current signal is out of phase with the voltage one rotating force would work against the other rotating force, Calibration was done in 2 parts, 240 vac and zero current moved the needle to 0 Watts increase in current the rotated the coil back up the scale.
Using tis principle and two conditioned analouge signals one AC volts the other ac amps into two op amps respectively and combine those outputs in a multiplying opamp should give a representative Power Output with Power factor included. ie when current or voltage is momentarily 0 the power is 0.
Multiplication requires 2 logerithmic amplifyers and a summing amplifier. for those who didnt know. Op amps are good at analouge maths. once comleted then digitise using an ADC
Jan 1, 2012. 1:51 PMlrdforster says:
circuit attched quite simple remember it releys on analouge measurment and simaltanious readings. The output would need to be calibrated with known inputs and powerfactor
Apr 21, 2009. 9:41 PMthecolorblue says:
I love this idea but I am really worried about opening up my fuse box to set it up (esspecially, since a lot of the technical stuff went over my head). Even if this setup is only 40% accurate, its a great example of what someone could do with a iobridge. This looks like a great weekend project and maybe another weekend just playing with google visualizations api. With more money, do you think it would be possible to make this more accurate?
May 20, 2011. 7:40 PMJ,R,D, Ltd says:
How has progress on the update gone?
May 23, 2009. 8:52 PMthermoelectric says:
Ooh, I can't wait to see how you do that. It will be really hard unless you can "correct" the misalignment of the current draw. This might give you some ideas (schematic down the bottom...)
I've been watching your live graph and it's amazing how many times it can peak at nearly 4kw's. What draws that much power?
BTW, Great instructable, when I try to do it I will use CT's. I doubt I will use the ioBridge because there isn't much of a DIY factor to that (It's also partially because I'm too young to have a paying job...)
Sep 25, 2010. 8:49 PMHightechk says:
i hope you know what your doing if you try this because you could easily kill your self. also i would recommend covering those open circut boards (dust and if you have children)
looks cool though im wondering wether i want to do this or just buy one?
Jul 30, 2010. 9:14 AMDavidRobertson says:
Correction. In step 2 it should read "2. AC Current Clamp. Stand-alone type what that will give an output in milli-volts per amp.".
Jun 7, 2010. 5:15 AMChookChooks says:
This is worth a look :
Power Monitoring, Weather Station Data, Server Performance, throw in some Local News and an interest in Australian Magpies..
and you found ChookChooks.com
Sing out if you would like to know more :)
Feb 15, 2010. 6:38 PMpaulstich says:
Good stuff!  Thanks!  I built this using the AD627 as you suggested.  Works great.  I'm using a homemade ammeter coil (based on the info in hydronics' $2 Carabiner ammeter) and an Onset Hobo U12 data recorder.  I would like to improve the rectification, and am thinking about trying a true-rms chip, like the AD737.
Jan 2, 2010. 12:30 PMStevens_Carl says:
            I sure hope your still responding to comments on this...
         I am in Toledo, Ohio and am currently using Toledo, Edison... I am currently paying $900.00 Mo. for my Electric bill. I am compiling a list of projects to help cut these costs. So far burning wood for heat. I have an extensive knowledge of Electricity and a some somewhat limited knowledge of electronics.
I am considering using current transducers mounted on all "hot" lines from each breaker 40 total to monitor the current draw from all circuits individually. My plan would be to cut power to certain rooms and circuits through out my house and monitor the current draw usage real time Via my Blackberry. As well as be able to cut certain loads on the fly. I don't know why but for some reason I cannot wrap my mind around the project in such a way to be able complete it. Any help you may be able offer would be very help full.
Apr 21, 2009. 3:15 PMjeremiahthebullfrog says:
Don't know what country this is but talk about dangerous!!! That's like a load of spagehetti in there! and why are your incoming cables exposed instead of being covered where they terminate??? Another thing is how do your supply company measure your usage? I can't see a meter.
Nov 24, 2009. 11:26 AMdylanwinn says:
1) In the US (California) at least, the terminals are left exposed inside the breaker box by the utility company, and covering them is unlawful because it could present danger when removing the covers.
2) In most places, the Meter is OUTdoors (where it can be easily read), while the breaker box is INdoors (where it is difficult for you neighbors to tamper with).
Jan 24, 2009. 12:38 AMElectron Wizard says:
While this can be a worthwhile project, there are some serious "gotcha's" that will limit is usefulness. Power is the flow of energy per unit time. One Watt is the flow of one Joule of energy past a point in one second of time. The circuit as designed is a positive peak detector with a time constant of about 0.5 seconds. This results in a snapshot of the current when it is at its positive maximum, and so we can only really calculate an energy flow at this instant. We are making many assumptions about what is occurring during the rest of the waveform period, and these assumptions can quickly lead us astray. One gotcha is discussed in the article; this is power factor. If the voltage maximum does not occur at the same instant as the current maximum, this will give us an error in our power reading due to our assumptions. The power factor will correct for this, but it assumes that both the voltage and the current are sinusoidal. The power factor varies as various devices are turned on and off, and thus we would have to know the correct power factor for all the devices and if they are running or not in order to make corrections. Switching power supplies and lighting dimmers create a non-sinusoidal current waveform causing errors that cannot be corrected for in this design, another gotcha. Here's an example: A common technique for lighting dimming is called phase cut-on, which turns off the current at its zero crossover point, and then turns it on after a delay that is constant for every cycle. If the dimmer was adjusted to supply half power to the lighting load, the current would be blocked after every zero crossover until the voltage was at its maximum, and then turned on. At that time the current would go to the same maximum as if there was no dimming. The circuit would respond to the same peak and would give the same power reading even though power was reduced by 50%! An accurate power meter has to detect the instantaneous power and integrate it over the unit of time, keeping track of the sign of the power. This is why they are so expensive. Any accurate meter would have to know the polarity of the voltage and the direction of the current. One last reality check. This design cannot differentiate between power flowing out and power flowing in. A power meter that gives the same reading for 1000 W as for -1000 W has some serious limitations. If you replaced your house loads with generators, could your power meter tell the difference? If not, can you really trust it? (The power company meter turns backwards if you put power into their line.) I appreciate the authors desire to generate an inexpensive display of power usage, and many of the ingenious ways he implemented it, but it will only give a broad generalization of power usage, which may be good for things like telling when your air conditioner is going on and off.
Nov 20, 2009. 4:52 PMjames.mcglashan says:
hey man that is the longest comment ive ever seen if i waned to write some thing like that i would make a new fourm and link to that topic. hehe instead if having a very long detailed comment.
Aug 14, 2009. 12:20 PMheltones says:
You are correct for all of these points, but I think you paint a bleaker picture than necessary. I agree that the power factor issue is a big gotcha. However, that can be estimated and/or short-term measured (seasonally, depending on HVAC equipment) to get a fairly reasonable idea of how to modify the apparent power to get real power. For that matter, the voltage is not a constant either, so it should be measured. It's generally 118-126 V at my house, with a long-term average somewhere around 122.5 V. That is another bit of uncertainty this method incurs. The average residential monitoring application (at least in the US) will not suffer greatly from lighting dimmers and switching power supplies. These are generally a small percentage of the load at any given time. I'd guess the clamp errors are greater, especially at low currents draws. There is a lot to be gained by a better understanding of the magnitudes and time of energy use and what's going on in one's residence. I think this project is great in both means and ends, despite the limitations. The system really needs to be repeatable more than it needs to be accurate to Watt (or Wh) to give good feedback to the home occupant(s) about energy use. It has the potential to still be more useful than the monthly kWh reading from the electric utility that comes another two weeks after that month ends. I just wanted to add a bit more positive spin to the measurements, because I think they still have a lot to offer.
Jan 24, 2009. 1:40 PMElectron Wizard says:
Jason; I'm sorry if I gave the impression that I didn't like your design. I came across your project while conducting a search, and now that I have had time to browse instructables, I fully agree with your characterization that simple and inexpensive are key elements. However, it was never my intention to dismiss your project, in fact I admire the ingenuity of it. I just wanted to point out the difficulties of measuring power. I would not be surprised to see an overall error of 30%, or even of 60% if measuring a dimmed load. This does not mean that the project is not useful. The ability to see loads turning on and off is very valuable. I would love to have a record of how my air conditioner is cycling so that I could see if my trials to reduce the demand are working, since power to run air conditioning is very costly. Monitoring an air compressor would be valuable, as would being able to see when your teenage came in late last night, or if lights are being left on. Lastly, my wife would certainly agree with your observation that my discussions are much too longwinded. She is often chiding me about this. Good luck with your projects, I am looking forward to seeing more of them.
Feb 14, 2009. 2:16 AMgeo says:
Hi Jason-- Analog Devices has several analog multiplier chips you will want to look at. Sadly, you will find that they're expensive as chips go. The "low cost" ones can be had for eight bucks at Digi-Key, though...
Jan 31, 2009. 7:53 AMlegless says:
just don't do it in OZ. We can't touch in the power box at all except for replacing a fuse or resetting a breaker.
May 22, 2009. 7:47 AMthermoelectric says:
You probably can't, but just do it when nobody's watching :-)
Mar 14, 2009. 3:48 AMchrisli75 says:
To be safe... Turn off your Main House Power.
Mar 11, 2009. 3:20 AMAdrianCronauer says:
Just to mention that the german http://www.enbw.com/stromzaehler/
(unfortunately this site is available in german onyl!) offers an online
counter. This device is connected via kinda powerLAN adapter to the customer's
Router which sends data to the ENBW. Furthermore the customer can check the
current electric power consumption with a computer based program. In addition
the customer does not pay a monthly rate but pays the actual power which has
been used. On the website of ENBW the customer can analyse the power
comsumption on a daily, weekly, monthly and yealy base.
ENBW offers two rates: high price Mo thru Fri 8am to 6pm and a lower rate
during the night and weekends.
Mar 4, 2009. 8:24 AMFoxtrot70 says:
Hey JasonT - To make your setup cleaner you can use current transformer rings. They install by disconnecting each of the two power lines sliding the transformer ring on each leg, then reconnecting the power line. The output is the same as the AC Clamp. I have a similar device I purchased commercially it works great!
Mar 3, 2009. 6:35 PMAndrew Heine says:
add cost calculation based on local power rates to show actual cost per hour
Feb 26, 2009. 6:11 AMJeyNyce says:
I didn't read the whole article so for give me if my question sounds silly, but could I use something like this to compare it with my Con Ed bill? I swear that sometimes I think they are over charging me! Thanks
Feb 21, 2009. 6:17 PMsydelbow says:
lol I need you to come to my house and create this again. It's fabulous, I wish I understood most of it. Does it come in handy for you? Have you discovered what takes the most power and what you can unplug? I'm so curious about my own home.
Jan 23, 2009. 11:52 AMuberdum05 says:
GET THEM LIVE TERMINALS COVERED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! DONT risk an electric shock when you could be enjoying your life
Jan 30, 2009. 9:42 AMdalesd says:
Correct me if I'm wrong, but there are no exposed 110 or 220v connections in the completed project.
Jan 30, 2009. 10:14 AMuberdum05 says:
No I meant the main incoming live power terminals which you said were live
Jan 30, 2009. 11:06 AMuberdum05 says:
No the red and black terminals inside the actual breaker box were live werent they??
1-40 of 89next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:jasonT
