Step 10Google Charts and Website Integration
There are a few features of the chart that I'd like to point out. First, it automatically updates every 10 seconds. It will continue to add more points for an hour. After an hour, data older than an hour will be scrolled off the chart to make room for new data. This limitation is because of the way Google Charts works. A Google Chart is created through the use of a URL. Since a URL is limited to 2048 characters, there is a limit on the amount of data that can be plotted at once. The other thing I want to mention about the chart is that it will automatically scale the Y-axis.
Happy power monitoring!
Many years ago when I was an apprentice I recall seeing an analouge Power meter which compencated for power factor. As I recall it had a voltage coil and Current coil combined in such a way they gave a Power reading.
The Idea was as the current signal is out of phase with the voltage one rotating force would work against the other rotating force, Calibration was done in 2 parts, 240 vac and zero current moved the needle to 0 Watts increase in current the rotated the coil back up the scale.
Using tis principle and two conditioned analouge signals one AC volts the other ac amps into two op amps respectively and combine those outputs in a multiplying opamp should give a representative Power Output with Power factor included. ie when current or voltage is momentarily 0 the power is 0.
Multiplication requires 2 logerithmic amplifyers and a summing amplifier. for those who didnt know. Op amps are good at analouge maths. once comleted then digitise using an ADC
I've been watching your live graph and it's amazing how many times it can peak at nearly 4kw's. What draws that much power?
BTW, Great instructable, when I try to do it I will use CT's. I doubt I will use the ioBridge because there isn't much of a DIY factor to that (It's also partially because I'm too young to have a paying job...)
