3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Realistic Wound FX
Step 2Building the Prosthetic
Begin by cleansing the desired application area, in this case my left wrist. Once the area is dry and clean, begin applying the first thin layer of Liquid Latex. You can use a brush, a wood applicator or a clean finger for applying the Liquid Latex. I find that the best results come from using your finger. Let the latex dry until it is tacky. (Quick Tip: Use a blow-dryer set on cold to quicken the drying process.) Allow the latex to dry completely if you wish to add another coat to thicken the base.
After the base coat of Liquid Latex has begun to dry, remove one square of toilet paper from a roll. Try to obtain a two ply kind with no texture or designs. Separate the plies and roll each side into a snake like structure. This will create the raised skin that forms the wound. Take one of the rolls and apply it to the latex base.
Using your finger apply Liquid Latex to the toilet paper now positioned on your application area. Be generous, blending the outside of the wound structure with your skin. The inside should be left at an abrupt edge.
Add the second piece of tissue to complete the wound. I prefer to join the top and bottom edges as to create a pool that will catch the stage blood when it is applied.
As you did with the first side of the wound, coat in a generous amount of latex, blending the paper into your skin.
1 comment
Oct 22, 2009. 12:03 PMzombiecore says:
we have a similar technique.  nice tutorial.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:Pull and Twist
