3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Realistic Wound FX
Step 5Applying the Make-Up: Highlights and Meat
Now it's time to highlight parts of the wound using a lighter colored make-up. I apply the highlights using a small flat brush only covering the higher sections of the application.
Followed by some texture using a texture sponge. You can use any textured sponge for this, I used a plastic hive like one I had on hand.
Now that the wounds has been blended into the application area, it is time to start working on the inside of the wound. I begin by applying some darker make-up to the inner edges of the wound to simulate stronger shading and add depth. In this example I used black.
After which I apply a dark red make-up to the inside of the wound.
Set the make-up using Neutral Set Powder and the same process as setting the latex at the beginning of the tutorial. Blotting the piece with moist toilet paper will bring back the color and remove extra powder. (Quick Tip: Setting make-up is the most often forgotten crucial steps in make-up application and results in running and ruined make-up at the first sign of moisture such as sweat or water.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:Pull and Twist
