3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Really loud DIY iPod Touch Dock with speakers
 My home made ipod dock from an old 2.1 speakers system.
First off all, i want to apologize for my bad english, but i hope you will understand me.
requirements:
Ipod
ipod dock adapter (it came in package with ipod)
ipod audio-video cable
speakers (winth integrated amp)
a few tools, little knowlage about electronic
Step 1Destroy
Destroy
 take a part speakers system
19 comments
Apr 29, 2012. 10:26 AMrapidprototyping says:
I have used NXT flat panel speakers without an amp for listening to music at night in bed. i tried using head phones not enough volume there even seting the headhones on your head . then you can toss n turn without having to constantly beaware of the head phones. I then tried the behind the neck style head phones again whowants be on their back all night sleeping in one position. i had battery operated amp plus nxt flat panel speaker it had pretty good sound amplification but a drain on batteries was constant cant expect them to last if left on while you fell asleep. now a solar battery charger and battery operated amp plus nxt flat panel speaker would be ideal dock. i noticed at secondhand stores they have small amps like trhis often for few dollars.
Aug 3, 2011. 8:11 AMhsarode1 says:
I dont know if this question is silly because i have a PC Desktop speaker which needs a input of 220v so can i power it by 9v. will it work.
Jan 25, 2012. 3:07 AMdog digger says:
no
Apr 21, 2012. 8:35 AMRirishi says:
dog digger, with all respect, but you're maybe not totally right. I don't think the circuit of the amplifier works on 220 volts. If you screw open the speaker box with the controls in it, you will maybe see a thing where the 220 volts wall socket wire goes in. You have to read what's on that thing. Maybe it tells you it outputs 9 volts of DC power, which means you can actually replace the wall socket wire and that transformator with a 9 volt battery! I don't know if this works with every pair of speakers, but my speakers do have such a thing ;)
Apr 21, 2012. 4:40 PMdog digger says:
Even then, most cheap speaker systems just run into a transformer and then the the circuit without any rectification. It might work. Just look at the output of the transformer and sometimes, depending on the system, it might work on a DC supply. You need to look inside the unit and check. No system that I've seen directly runs on 220v. I've seen 35v rails as the most common. The real answer is, who knows?
Aug 3, 2011. 8:13 AMhsarode1 says:
Hey r they Speakers u r using working on DC Or AC.
Jan 25, 2012. 3:08 AMdog digger says:
The amp is DC and AC goes to the speakers
May 30, 2011. 6:25 PMshadowtuy says:
can it charge the ipod to?
Aug 2, 2010. 12:28 AMKirbsome! says:
Sorry if this question seems silly, but what about the "Apple Connection Chip" that the iPhone / touch requires for output through the dock cable?
Dec 18, 2010. 2:26 PMpaul1407 says:
How did you connected the ipod cable to the amp?
Can you please tell me, you inspired me so i don't have to buy a new speaker/dock:P
Feb 5, 2011. 7:09 AMmichielvg says:
hey i just saw your project. and it's realy amazing.
but can you explain how you connected the ipod cable to the amp, so I can built it also?? ;-)
Jan 4, 2011. 12:29 PMmilesduggan says:
This is so badass! Love it!
Apr 9, 2010. 3:27 PMstevenmeyerjr says:
 Im going to build this, if you could just please explain how you got all of the boards and switches. Did you just get it off of an old radio or something?
Feb 18, 2010. 12:57 AMisacco says:
The smart point of this project is having efficiently re-used the subwoofer cabinet.
A little more explanatory text would be useful for Instructable clarity.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:skrbicdu
iOS and Android application developer, and a carpenter.
