85 Inch Rear Projection Wiimote IWB (Interactive White Board)
This Instructable show how to set up a Wiimote Interactive Whiteboard using Johnny Lee's technique. There are other Instructables dedicated to setting up and utilizing the Wiimoteboard, so I am not going to cover the basic set up steps.
I originally set up a front projection system in my classroom with only one Wiimote and I found I had major tracking issues and it was difficult for my students to understand they couldn't block the camera in the wiimote. So I decided that I wanted to make a large rear-projection screen set up in my class.
At first I had trouble finding information about this set up. It is more time consuming to make so I assumed that is why it not commonly used. Originally I tried what some others had done, trying to use frosted glass or plexiglass but I got really poor diffusion. I also tried the Frosted shower curtain approach which also gave poor results (hot spotting).
I finally decided to spend the $37 dollars on actual rear projection material. And the results blew my mind. I then built a frame and support legs with wheels for my screen, all in all it cost me about $75 - $100 including the screen material. This is by far the easiest to use and explain wiimote set up and my students love it.
Step 1Building your Screen
I purchased my screen material from Rose Brand Grey Rear Projection Screen material I purchased two yards @ $16.95 a yard. This works very well with my projector, 2200 lumens, with no real hot-spotting. You can find it here - http://www.rosebrand.com/product703/Projection-Screen-and-Rear-Projection-Screen.aspx?cid=218&idx=1695&tid=1&info=Screen%2bby%2bthe%2bYard
I built my frame out of 1 1/2" by 1 1/2" by 6' boards. ( a 2x4 ripped in half long ways). My dimensions were chosen by setting up my projector and seeing what size was comfortable for me. It ended up being 44 1/2" by 71" (just shy of the two yards of screen material length). So the screen diagonal came out to be roughly 86" which looks beautiful.
I used L-brackets I bought from Home Depot, so that I did not have to cut 45 degree angles and worry about matching them up. After building I found that the joints were a little week so I also attached a metal strap at each corner to give it more stability.
After the frame was build I used a regular stable gun to attach the screen material. I wrapped the material all the way around and stapled it on the back. I folded the material a few times in order to give it some strength where the staples went through.
17 comments
Sep 2, 2009. 5:25 PMmatt ledding says:
I heard some good stuff about weaving together wax paper as a backdrop. Where do you place the wii in the set up from behind, cause you must get very clear light blobs...
Sep 4, 2009. 12:21 AMmatt ledding says:
Tom, you have very much inspired me to start playing with retro projection, although as we have less class space in Spain, a mirror or two might be in order... if the wii is on top, everything should get passed through the mirror, I suppose.
May 19, 2011. 8:26 PMjammin0 says:
Did you ever follow through on adding a mirror to shorten the throw distance? I really want to do this but with a piece of acrylic on the front so I can use a pressure sensitive pen. Acrylic kind of blows my budget and it seems like it would have to be really thick in order to be sturdy at such a big size screen. Check out this instruct able I just threw together for how to make a pressure pen. http://www.instructables.com/id/Pressure-Sensitive-Tip-IR-Pen/
Mar 10, 2010. 3:42 PMmatt ledding says:
 I keep getting ghosting (glass) or crap reflection (plastic ikea mirror)  any luck on your side?
Sep 2, 2009. 5:32 PMmatt ledding says:
By the way, what are you using for software on the board? It looks great?
Apr 18, 2011. 8:35 AMsgorman1 says:
This is incredible! Great job and awesome instructable! I need to look at Johnny Lee's wiimote instructable for sure. Thanks for putting this together!
Nov 20, 2010. 7:47 AMulfilas says:
what distance is the wii from the screen? I'm trying to work out maximum screen size/distance... Front projection will work from a much further distance of course - but like you I'd rather use rear projection!
Mar 24, 2010. 7:48 PMajrisi says:
 While I hate to nit-pick such a wonderful article, it should be noted that what you type as "whole(s)" should be "hole(s)". A "whole" refers to a single entity including all subcomponents without exception, while a "hole" is an opening into or through something.
Otherwise, very nice!
Dec 29, 2009. 8:15 PMzyzar says:
Hi,
i'm curious that can I use projection screen material in different brand? and can wii remote capture IR source through the projection screen material?
Jan 4, 2010. 10:56 AMthegallery says:
Are most projectors capable of projecting from the front and the rear, or do you have to get one that is specifically a rear projector?
Jun 15, 2009. 6:15 AMwolfsingleton says:
Great usage of the technique, really well done. I had considered Johnny's idea as a nice novelty, but didn't really have a use for it, now I could really see this for doing graphic work and presentations. Thanks for another reason to avoid doing actual work for awhile lol
Jun 12, 2009. 2:25 AMtheRIAA says:
you should add a link in the beginning because I was a little confused there for a second.
Just select "Johnny Lee's technique" in your intro, click "link" and paste "http://www.instructables.com/id/In-depth-Wiimote-Whiteboard-How-to/" as the address
really cool though, it's like the internet hands-on, great build.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tombarb
