UPDATE: I've redesigned the stakes for this year's burn. I think they are work better than the old design because they're more reliable. Maybe it's because I'm not the best welder, but some of the loops and caps have fallen off the old stakes. My new method seems like they will last longer without any problems. I've listed the new materials in the list of materials. I may weld a loop to the nut for holding rope and ratchet straps. It would be easier than using the carabiner. I used a grinder to sharper the end of the rebar a little to help it go into the ground with less resistance. Pulling them out of the ground was easy. I used a wrench to turn the stake while pulling. The washers help give extra grip. Use Loctite on the threads to keep the bolt from coming out (or weld it in place).
Remove these ads by
Signing UpStep 1Materials
New stake materials:
1. 1/2" x 24" rebar - $1.50
2. 5/8" x 2" nut - $1.20
3. 5/8" x 1" bolt - $0.70
4. 5/8" washers (2) - $0.20
Original stake design:
2. 3/8" x 2" steel rings - $0.95
3. 1/2" black pipe cap - $0.49
and the ring is expensive to buy by itself
what I would use is a large chain, cut down each link and weld with the REBAR inside the link end. set the link down, and place the REBAR end into it standing up and weld from the bottom,
you end up with a solid flat top to pound on, and still have a ring. and it won't disintegrate, only bend, and if the weld starts to crack, you can reweld. You can't do that with a cast cap.
Get a can of white, and a can of bright orange paint. first paint white, then overpaint with orange. it will really stand out
One trick that I use for removing the steaks from the desert floor is a medium size monkey wrench, just grab the steak mid way, pull up and twist. They come out of the ground without much effort. Beats pushing them back and forth.
Gravity Boy
The "easiest" to learn, for home-metal butchery.
ANY welding machine can weld ANY thickness.
ok, not strictly true. too THIN can be a problem.
but too thick is easy to overcome. You lay down many smaller weld beads, instead of one large bruteforce weld bead.
Even a homemade welder could weld 4 inch thick plate. but you would need to bevel the edges, use a LOT of filler metal, and it would take quite a while to finish. It WOULD work though :-)
The other limiting factor for the cheap welders is "duty cycle".
that's how long it can run before needing to cool off. For instance, a 40% duty cycle machine could probably weld a 3 inch bead(30-45 seconds), before needing to NOT weld for a min or two. The high end machines($500+ usually) can often acieve 100% duty cycle, at medium or low settings. To do heavy welding, non-stop, you're gonna be looking at BIG money. For small welding projects like this, it's not an issue cause you're "off cycle" is usually more than covered, getting things aligned, post-weld cleaning(you ARE removing the slag, right?) and positioning for the next tack or bead.
Don't think you HAVE to get a gmaw machine though.Simple stick welding "buzz boxes" can be had for under $100us. and can use welding rods as cheap as old coat hangers, random pieces of wire, I've even seen pieces of chain link fence used (though beware ANY welding/heating/soldering of galvanized materials). Beginning welders do tend to have more trouble striking, and maintaining an arc with stick welding, and it's much harder to weld "sheet" metal(under 1/8th inch). But in exchange, you get cheaper rods(as compared to the more expensive wire reels and possibly gas tanks/refills if you don't use cored wire) and you GAIN the ability to CUT metal with your welder.
ok, enough of my spiel.
Consider, at least taking a weekend welding safety course, at the local university/community college. and if you're gonna be doinging anything that HAS to stick, take instruction in the type of machine you intend to work with. It's a lot easier to get a weld to LOOK good than it is to make a weld ACTUALLY good. If in doubt, hit it with a sledgehammer. If it bends, it's good. If it breaks at the weld, it's not.
Duty cycle is important as someone else has mentioned. If you're looking for a 100% duty cycle unit (the units that are run in fabrication shops for many hours on end) I would guess something more along the lines of $5000+ dollars if you want a quick run down of some units a reputable company has check out http://www.hobartwelders.com/products/wirefeed/ or look up lincoln or miller mig welders.
My best suggestion would be if you have a friend that works somewhere that has a mig welder see if they can hook you up. If not that maybe hit up a fabrication shop, auto repair, steel shop or even throw out an ad on craigs list maybe. If you're wanting to make these you might as well do it once and do it right.
