loading
Step 2: Check The Drip Mechanism
The drip mechanism is pretty simple on most of these lamps. To check it just put water in the top chamber while the bottom of the lamp is removed. With the control lever or nob set in the on position it should simply drip water like in the video and photos. Not too complex. If the control lever/nob has a lot of play in it you might end up with problems. The water may drip too fast, potentially dangerous, or might let gas leak back up into the water chamber, non-functional.
You can see the valve functioning in the video. I just made sure it would both drip and close.
It's probably best to use some sort of filtered water in the lamp but any water will do in a pinch. Cave water works just fine as does rain water. Note that particulates will possibly permanently clog your water valve and water in caves is pretty much universally high in mineral content.
I have yet to deal with a broken or loose valve so I can't advise on a fix other than salvaging parts from another lamp. The people I know who use these lamps that have encountered a loose valve suggest turning those lamps into art. Probably more creative uses for a dead carbide lamp but you get the point.
Acetylene can be dangerous. Don't risk injury. Too many old lamps laying around to mess with a faulty one that can't be fixed.
All of this comes with the caveat that if you are good at brazing and pipe sweating you can repair most any of these lamps. Even things like cracked bases and loose gas tubes can be repaired if you know how. Unfortunately if you don't and try without proper instruction you are likely to set your head on fire. ...literally.
Please use caution.
<p>Good 'ible. Glad to see others enjoy these historical devices. I've got more than a few of these. I used them when I was caving. I started picking them up, when I was about 12(1964). Got my first on from one of my customers, on my paper route. </p><p> Over the years, I've repaired quite a few. One of your fixes, is easily performed underground, with a small rock. If you happen to run into a stalactite, and bend your reflector, so it flops around. Take it off, hold it face down in your hand, and lightly tap it with the rock, around the center hole. That'll tighten it right up. I've always been partial to a shiny reflector. The lamp puts out about 2 candlepower, so any reflection forward, gives you better lighting. </p><p> I hadn't tried peeing in the lamp. Carbide and urine, make a wicked smelling brew, that will nauseate a buzzard. </p><p> If you have spent carbide, be very careful. You can't state this enough. We used to put our spent carbide in bread bags (2, doubled) and pack the ash out of the cave.</p><p>On one trip, we were trying out &quot;New&quot; cave packs, made from two Clorox bottles, with the bottoms cut out. They are quite useful, when sliding your pack through mud. They will, however, trap the acetylene, that leaks from the breadbags. The explosive range of acetylene is 2- 98%. In other words, ad spark, boom! And, while I was following one of my fellow cavers, through a 2 1/2 foot high crawl, he banged his helmet on an outcropping. That caused his carbide lamp to drop a bit more water, in the chamber. His flame jumped out about 4&quot;, and he got a bit too close to his Clorox &quot;Pig&quot;. All I could see was fire around his backside, with the smell of burning hair. He wasn't hurt, but he was in full reverse panic mode, and had no facial hair left. </p><p> Always dispose of the carbide ash properly. Slobs leave it. Also, don't dump it outside the cave. It will kill a cow, and they think it's quite tasty. Farmers are not amused. </p><p>I didn't know it was good for a garden, though. Thanks. </p>
Hey! <br><br>Thanks for sharing. I left my caving pals back in Indiana and don't get underground much here in CA but I miss it. Cavers are a unique bunch. Some of my favorite stories over the years have been caving stories. <br><br>
<p>how long do they run for?</p>
Depends on a few variables but you can get a couple hours from a full load of carbide in a lamp. Really useful old tech.
<p>Thank you.</p><p>I am also the grandson of a coal miner and I've been wondering how to put Grandpa's lamp back into service. Unhappily, the mines killed him long before I was born.</p><p>Dad tells me that the miners - at least in Grandpa's mine - would routinely blacken the reflectors of their lamps. Evidently a brilliant white light was in the pitch black of the mines was thought too hard on the eyes. </p>
Wow, thank you for sharing that! Having used carbide lamps for caving, it makes perfect sense and also may be why it is so rare to see an antique lamp that shows any sign of a polished reflector. It's important to relate things like that so the collective &quot;we&quot; don't forget.
Sorry, I walked away from the tablet for a couple of minutes and when I got back to it the display read "thanks for flagging". <br/>Totally inadvertent. Great instructable.
Great Instructable! I collect, and sometimes still use these underground. At last count I had around 40 including three of the large supervisors lamps. When the base is tuck I find a couple of days soaking in white vinegar can make a big difference. Really stubborn cases may require a little heating of the top, but you have to be careful or you'll un-solder some parts that are awkward to re-solder. <br> <br>I've never heard of anyone spitting in the water reservoir but I know of many cavers who urinated in them to get by. I think the first time I heard of this was in the book &quot;The Longest Cave&quot; about Mammoth Cave in KY. Never had to try it myself.
My grandfather was from coal mining country we used to have loads of these things. You do know that the old timers used to spit into them to generate the gas right?
(Last pic) Haha, don't sneeze! And yeah they are bright... I guess I'll settle for Carbon Arc Lamps since calcium carbide is a bit off my league.
things we do in holland with acythelene gas (carbide+ water)<br>http://www.youtube.com/watch?v=kk5YUQPNkEw 3300 L of acytelene gas...<br>http://www.youtube.com/watch?v=0jYrrMU7s_c<br>way more fun :)
Dat is geweldig!
idd, ga het dit jaar ook zelf doen, maar dan gewoon met een melkbus<br>(gonna do it myself this year, but with a normal &quot;milk can&quot;)
I just got one of these awesome little guys at work today. I knew that it was some kind of lamp but what a treasure!!!! I had no idea it was so cool a device.. now to get it working........
Cool stuff. This could be a very good addition to some kind of sculpture, or on a car... I imagine it would need some sort of shield on it, but the epic nature of a machine that creates light with little acetylene fires would be more than worth the tinkering. :-)
It's easy to produce oxygen too - I wonder what the potential might be for a bit of small-scale 'survival' welding using easy to obtain feedstocks and no mains electricity or commercially-produced gases? I can feel a project coming on...
I'd really like to know how to do that. I think you'd need a custom rig rather than a standard lamp but it wouldn't be that tough to build. How would you produce the oxygen?
By far the easiest way without access to a store of chemicals would be to let nature do the work - a bathtub full of plants with a slack polythene 'bubble' over the top would collect oxygen given off by the plants, you could see how your harvest was doing by seeing the 'bubble' inflate. If the 'bubble' was gaffer-taped around the edges of your bathtub you could apply enough pressure to force it out of a jet by simply resting some weight across the top of the bubble. Something as rough as this isn't going to have a high duty-cycle - you won't be able to run for long before you need to let it rest a day or two to replenish, and the oxygen isn't going to be very pure either... but it should be good enough to neutralise the otherwise carburising flame from acetylene and make it possible to braze cleanly with it at very least - and once made it's completely independent of any outside feedstock. One furhter thought for anybody considering an experiment along these lines - acetylene safety... it's 'very' unstable if you attempt to store it under pressure and it will kill you if you let it... unless you you know what you're doing with it, Darwin will get you sooner or later... commercial acetylene is usually stored dissolved in something more stable like acetone to make it easier to handle. The Wikipedia page is well worth reading to see what else you can do with acetylene too... it's the basis of all manner of potentially-useful stuff. :-) http://en.wikipedia.org/wiki/Acetylene
My Grandpa has on of these old things just sitting on a shelf in his garage. I'm gonna have to rebuild it for him. Thanks for the info!
Awesome! Feel free to pm me with any questions and post a photo or two.
Nice. I have not fooled with mine since effective LED lamps became popular. My flame tip is a press-in. I got it to fit on my screw style lamp with some soft solder. I don't have a local source for the calcium carbide nowadays. Online order will require an extra hazmat fee. For a tip cleaner, we always just got a two inch length of lamp cord and cut through the insulation only about half an inch. This would free up a bundle of thin copper strands useful for tip cleaning. Make several. Remember not to venture underground without three working independent light sources and a few buddies to stick with at all times.
I have a half pound on order now. Wasn't too bad on eBay. Guessing that will last me a while but I was thinking I'd go ahead and stock up soon just so I have it. Putting a lamp in our disaster kit. I'll try to make a DIY cleaning tool and post some photos. Nice to know someone else in our community has used these. :)
nice job. to help you out next time though, your vernier caliper has an ID gauge on the backside of the OD gauge. there is also a depth gauge usually on the other end of the caliper. (perhaps you knew this, but if you didn't, i;'m sure it will help you out in the future).
I was just being lazy and keeping the LCD upright but thanks! lol, I was only using the caliper because I couldn't find a tape measure. The tolerances on wool felt are pretty sloppy.
thats that giant little zippo, the silver one? how much is it?
It's a "carbide candle" for blackening rifle sights, not a Zippo. Runs on carbide and would make a terrible lighter. Not sure if they even make those anymore. Might try eBay or check with Ray-Vin.com
why couldn't you use that as a lighter? Look at the flame on that other one!
While you can certainly set fires with them they aren't something you can just grab and flick to turn on and off. Once you add carbide and get them going they generate acetylene for several hours whether you light them or not and there is no way to stop the gas or contain it. So, if you light them they burn for hours and if you don't light them they continue to pump out flammable gas. They also produce a sooty carcinogenic flame you wouldn't want to inhale smoke from. They also produce caustic lime as a bi-product of the chemical reaction that produces the fuel. Caustic lime can and will cause serious chemical burns if it gets on your skin for any length of time. It would also be expensive to operate for something as trivial as using it for a lighter. Precision shooters sometimes charge and use them intermittently on ranges during competition but they are still generating acetylene continuously the entire time. This is about a solid a caution as I can give. They aren't lighters and aren't suitable for use as lighters. Just don't, you'll quite possibly blow yourself up. Just buy a BIC or use a less cool looking but safe Zippo that won't kill or injure you.
Fair enough, I was not aware that they produced acetylene aswell!
Yeah, they are totally awesome but they have some drawbacks. *** If you want to buy one and try it out for party tricks, go for it! Just don't want this Instructable to give anyone the wrong idea. *** On the up side, carbide lamps produce very bright white light and until LED's got cheap and plentiful you could get far more hours of light per oz from carbide versus batteries.*** LED's are still not very good at keeping your hands warm. :) *** Like I said, go for it but don't think you are getting a simple low maintenance tool. Thanks for asking though, I'm sure others will wonder the same thing.
Neat. I like certain old-time stuff. What type of fumes do these put out? Is it safe to use indoors for, say, 4 hours at a time?
These lamps run on calcium carbide which produces acetylene gas when it comes in contact with water. It makes a very bright but sooty flame. It's also a fire the same as any other acetylene torch, it just makes it's own acetylene. In a typical well ventilated room. Four hours would probably be fine. That's about as long as one "load' or "charge" of carbide will run a typical lamp anyway. They do however produce a good deal of heat and in most cases the flame isn't covered. So, you could in theory run one indoors but it's probably not the best idea outside of an emergency situation like a power outage. ...in short, as safe as any small open flame can be inside.
About This Instructable
58,023views
70favorites
License:
More by Culturespy:Carve a bone needle for naalbinding 9 Volt battery adapter for Arduino Cure your own olives
Add instructable to:
