Yes, the "bitmap-bandit" is back......This project is focused on the typical Shimano Hyperglide hub circa 1997-ish, but covers most mid-level freehubs on the market today. Designs may vary between manufacturers, but the basic principal remains amongst many others. Some information provided here applies to ALL bicycle hub-bearings in general, so this is worth a once-over by those interested in DIY bicycle maintenance.
Since I lack the specialty-tools, and you might not have $25 to spend on each tool required as well, I will demonstrate my method for you to try at your own risk.
Please review the entire project before attempting to start this for the first time, and be meticulously clean with your workspace. Hair, lint, and dust can undermine the whole of this project, so treat this as a surgical procedure. Effort taken now toward perfection saves effort later walking home and getting new parts later on.
The picture will show you a cross-section of the typical Hyperglide freehub used in this project. I will make reference to the color-coding in following steps and reference this image again...
This project is for those serious about longevity of their machine....The careless need not apply...
USE OF "IMPROPER" TOOLS IS NOT AN APPROVED METHOD IN A COMMERCIAL ENVIRONMENT. NO RESPONSIBILITY FOR DAMAGE OR MISUNDERSTANDING OF THESE STEPS SHALL BE HELD UPON ME, THE AUTHOR. USE THESE METHODS AT YOUR OWN RISK. Many of these parts are made of case-hardened-steel / triple-tempered Chromium-Molybdenum, which is very to extremely brittle. Use eye protection and great care when exerting stress on these parts with the dictated method. Use the minimum force possible and do not put the face or the eyes within view of brittle parts or serious injury will result. Shattering of any such part can result in a spark and a projectile traveling at greater than 2000 feet-per-second, so don't think you have an ice-cube's chance in a fusion-reactor-core's chance at dodging it.
I thought I had these in focus, but it seems the focus-finder does not have good aim on my camera. My apologies for the blurry pix, but you should get the idea.
As I like to say, "Use care or lose hair" (applied to loose hair around mechanical equipment....same philosophy applies)
If this is your first attempt, I recommend much paranoia of part-explosion and attempting this on a non-valuable part as practice first. Attempt this only with a laced (already complete) wheel. NEVER clamp a freehub in a vice for ANY reason, or any part of it thereof.
If you have read this far, I take it you are serious about doing this as safely as possible without all of the specialty tools, and understand the risks. If so, proceed...Refer to the shown image or save it to your computer for reference as needed...
On to step 1
Remove these ads by
Signing UpStep 1Remove the cassette lockring
Basically use a pair of needle-nose pliers on the bearing-cone-locknut as if trying to remove it, but wedge it's "noses" into the splined keyway of the external lockring....Hold the sprockets firm as you try to turn in the direction that they freewheel. For the right-handed wheel, this is the same "righty-tighty / lefty-loosey" method, so force the freehub lockring to turn counter-clockwise.
The external lockring is a "right-hand" thread....Anytime when working with bicycle drivetrains, always remember the direction of pedal pressure. this will always be the direction of tightening, so the CCW direction of the freewheel spinning is often the "loosey-way"...All rear hubs incorporate the RH-threading when the drivetrain is on the right-hand side.
Anyway what I do to inspect:
1) "visual inspection" breakout magnifying devices and have a close look at the surfaces and note the pits and holes in the cups and cones!
2) "tactile inspection" drag little finger nail across bearing surface and feel for the scratching of the pits....
After frightening self into realising this hub would very quickly fail and now convinced that this hub is well and truly broken, explore options for a new hub and wheel rebuild ... and instructable!
The pictures really helped in packing my wheel bearings.
As far as the play in the hub, you should try readjusting the bearing cones to take up that slack. If the hub has been ridden a long way this time, you will likely have to replace the cones as the preload can never be set properly again due to improper wear. If the cups are galled or pitted, just get a new hub as they are typically not meant to be replaced. Consider a set of cone wrenches for your hub (forget the locknut as you can get to that with standard tools).
As far as choosing a hub, it's mostly about how much you want to invest, just make sure you get one with the correct number of spoke holes (hyperglide and uniglide require you to specify the number of cogs and the spacing). If you are going to replace the wheel entirely, try to find the highest spoke count you can. Mountain bikes should have no less than 32 spokes, well-built should have 36. A lower budget can get you a Shimano Deore XT, or you can go up to something like a Bulle'seye, which has a large barrel and cartridge bearings that never need adjustment. Go to a cyclery (not a dept. store) to get a better idea of your options if you decide to replace it, and shop around...try eBay even. Finally, aluminum rims are stronger than steel, so don't even think about steel rims.
You can likely try a thrift store or even stalk a residential building's bike rack for unwanted bikes, which is much cheaper than attempting to replace a whole wheel or even labor for replacing a hub.. Often times people just leave bikes behind, costing a great deal for disposal, so you may be doing the manager a favor. The thrift store can turn up some surprising results if you look hard enough, and often buying the whole bike is cheaper than just getting a wheel new, just make sure to match the number of cogs to yours if you use any kind of indexed shifting (Grip-shift, etc). The rest of the bike can be kept for backup parts if needed, or even a backup bike should you manage to break the frame.
If your bike got hit by a car, you should inspect the welds for signs of fatigue. The easy way is to scrub along each weld with a very-stiff plastic-bristle brush....If paint flakes off, the frame has been compromised and may fail. In such case it's best to destroy the frame (so noone else salvages it thinking it's safe) and dispose of it.
Help me get my forum off the ground and ask your advice on my board http://pitchblack4.12.forumer.com/ and I can help you without taking up too much space here.....I am rather....verbose...
Cheers!
