Rebuilding a Spoked Wheel for the Royal Enfield Bullet
Step 1Preamble and Layout
Preamble and Layout
This is a first for me both tackling a wheel rebuild as well as working on a motorbike so I stand to correction in respect of my terminology/procedures.
Here Im going to tackle the front wheel, bearing in mind that there are 2 different types of spokes in the front wheel. There is the slightly longer 144mm one, and a shorter one 142mm. In addition to the length of the spoke, the 2 types also have different amounts of bend in the hook, which can be seen more clearly in the second pic.
The reason for this is that the wheel must be centered between the front forks, swingarm in the case of the rear wheel, to maintain correct balance and symmetry. In order to achieve this, the rim must be slightly offset with regard to the hub to achieve the correct wheel symmetry. In this case its offset to the LHS (left) when looking at the bike from the front, which I call the speedo gear drive side. This means that the shorter spokes will be on that side and the longer ones on the RHS (right) or brake linkage side.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:petercd
general bloke type of tinkering
