It's works using only two low power transistors and two nickel metal hydride batteries (Ni / MH).
The case is made with 3mm cardboard for making it as light as posible.
Ps: I'm from Argentina so let me know for any grammar mistake
Remove these ads by
Signing UpStep 1Materials
A piece of 3mm cardboard
A cutter
Some glue
Screws
Separators
For the circuit:
R1= 4k7 resisor ( yellow violet red)
R2= 1M resistor (brown black green)
Q1= BC548 or 2N3904
Q2=BC327 or 2N3906
C1= 10uF capacitor
2 AAA batteries
Extras:
A batteries charger
A wire for connecting the amplifier to the sound source
A wire for connecting the amplifier to its charger
Would it be possible to use a more robust set of transistors and higher uf caps and increase the voltage? Maybe drive a little bigger of a speaker.
Dunno about the input impedance...But try it :P
If you are smart you might wanna build something like:
http://runoffgroove.com/littlegem.html
Easy as pie
or
http://www.beavisaudio.com/projects/NoisyCricket/
Better version ! :P Props to Dano the designer.
These are all based upon the allmighty Smokey amp.
Maybe you should just buy one of those ;)
so i prefer this one
OP-Amps circuit mostly use IC's for the bigger gain they can deliver.
LM386 is the most used audio amplifier in DIY and guitar effects.
Its reliable, sounds good and is easy to work with.( As in one chip and two capacitators is the bare minimum for a working guitar amp. eg Smokey amp by Zinky electronics)
So please don't give your opinion.
The misspelled word of the day is:
Mispell
On your strip board, why did you put your components so far from each other?
They won't bite each other!!
Can I hook up 5 big speakers to this amplifier?
"Ps: I'm from Argentina so let me know for any grammar mistake"
Well, i only found one:
It would be more proper to say "Let me know about any grammar"
Ive been looking for an ible like this all over instructables, and have finally found it thanks to you:) Thanks!
can u please tell me what is the output power of the amp ???
hey i was able to make your project!
It could be anything, in spanish we name the transistors with a "q"
