3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rechargable pocket sized amplifier
In this instructable I gonna try to describe how to make a simple rechargable pocket sized amplifier.
It's works using only two low power transistors and two nickel metal hydride batteries (Ni / MH).
The case is made with 3mm cardboard for making it as light as posible.
Ps: I'm from Argentina so let me know for any grammar mistake
Step 1Materials
Materials
For the case:
A piece of 3mm cardboard
A cutter
Some glue
Screws
Separators
For the circuit:
R1= 4k7 resisor ( yellow violet red)
R2= 1M resistor (brown black green)
Q1= BC548 or 2N3904
Q2=BC327 or 2N3906
C1= 10uF capacitor
2 AAA batteries
Extras:
A batteries charger
A wire for connecting the amplifier to the sound source
A wire for connecting the amplifier to its charger
274 comments
1-40 of 274next »
May 24, 2012. 9:28 AMBegradoo says:
I built this little amp and it works great considering its simplicity and low voltage. It drives cell phone speakers especially well.
Would it be possible to use a more robust set of transistors and higher uf caps and increase the voltage? Maybe drive a little bigger of a speaker.
May 23, 2012. 7:17 AMmamajr96 says:
How exactly do you make the PCB, understand you need to print the PDF, but what exactly do you do.
Jan 4, 2011. 1:10 AMdannyo013 says:
I was wondering if there is a way to make this with a 1/4" input jack for electric guitars. Would make a great portable amp.
Mar 27, 2011. 2:24 PM-Syrus- says:
How 'bout just adding a 1/4 jack and trying it out?
Dunno about the input impedance...But try it :P
If you are smart you might wanna build something like:
http://runoffgroove.com/littlegem.html
Easy as pie
or
http://www.beavisaudio.com/projects/NoisyCricket/
Better version ! :P Props to Dano the designer.
These are all based upon the allmighty Smokey amp.
Maybe you should just buy one of those ;)
Apr 21, 2011. 3:50 AMrobot1398 says:
but they need ic this dosent
so i prefer this one
Apr 21, 2011. 12:00 PM-Syrus- says:
Then please, tell me what is wrong with using a IC?
OP-Amps circuit mostly use IC's for the bigger gain they can deliver.
LM386 is the most used audio amplifier in DIY and guitar effects.
Its reliable, sounds good and is easy to work with.( As in one chip and two capacitators is the bare minimum for a working guitar amp. eg Smokey amp by Zinky electronics)
So please don't give your opinion.
Mar 1, 2012. 4:26 PMMr_mojo says:
Sometimes it's easier to obtain some components such as transistors and capacitors, whereas specific ICs have to be purchased. I for one will be building this as opposed to one of the better ones which use an IC for that very reason, I'm on a very low budget and have these components (or similar once which will suffice) to hand. Just so you know you've brought an extra member to Instructables. I was looking for a schematic for a simple push pull audio amplifier when I found this one, and on reading your comment and finding it so rude I thought I'd sign up and give my reasons for wanting a simple amp as opposed to one that would require me to purchase anything.
Sep 30, 2011. 1:45 PMplmqaz1243 says:
Wonderful world we live in, when people are shunned from giving their opinion by some guy who... I don't even know what you do. Great job.
The misspelled word of the day is:
Mispell
Mar 15, 2012. 7:08 PMbuilding_boy says:
Not asking, commenting he is sooooo cute!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 15, 2012. 1:08 AMT-K says:
Do I.C. Mr Resistor?
Mar 3, 2012. 5:19 PMspystealth1 says:
That's an interesting way of creating a project box. Usually someone would get some sort of plastic container and paint it, but you use a kind of cardboard wood and instead of paint, you use paper.
Mar 6, 2011. 2:27 AMrobot1398 says:
some pics
Jul 11, 2011. 10:02 AMBiggimac says:
Had to ask!
On your strip board, why did you put your components so far from each other?
They won't bite each other!!
Jul 15, 2011. 6:41 AMrobot1398 says:
i know but i had of this size and that time i was not knowing how to cut a strip board
Mar 1, 2012. 4:14 PMMr_mojo says:
You use a sharp stanley knife (thats what we call them in the UK but I've seen them called box cutters on here?!) anyway you just score it with the knife then snap it.
Feb 26, 2012. 1:26 PMdidgitalpunk says:
what is the capacitor voltage? i don't think a 35V 10 uF one would do right
Feb 26, 2012. 4:48 PMdidgitalpunk says:
but will it act exactly the same?
Feb 2, 2012. 7:53 PMTyto Productions says:
What kind of speaker did you use? It looks like a computer speaker. Would any speaker work?
Feb 1, 2012. 12:13 PMlukeD says:
great ible *5
Can I hook up 5 big speakers to this amplifier?
Jan 12, 2012. 5:39 PMschumi23 says:
Great ible!
"Ps: I'm from Argentina so let me know for any grammar mistake"
Well, i only found one:
It would be more proper to say "Let me know about any grammar"
Ive been looking for an ible like this all over instructables, and have finally found it thanks to you:) Thanks!
Dec 30, 2011. 7:12 PMusbg3rd says:
it is not properly biased it clips the portion of the audio signal (negative crust)
Dec 30, 2011. 9:49 AMusbg3rd says:
hello
can u please tell me what is the output power of the amp ???
Dec 27, 2011. 11:17 AMMr Sinster says:
http://www.instructables.com/id/Yet-Another-Pocket-Size-Altoids-Speaker/
hey i was able to make your project!
Nov 10, 2011. 1:12 AMwunderdog317 says:
in step 7 what was that thing not the walkman
Oct 20, 2011. 1:14 PMecopp96 says:
que tengo que hacer para conectarlo a 12 volts?? Me encanta este proyecto, lo hice pero tiene mucha interferencia y quisiera uasrlo en el auto pero con el encendedor del mismo que tiene 12 volts. Saludos y gracias por el circuito. :)
Oct 20, 2011. 5:48 PMecopp96 says:
hay alguna manera de reducir la interferencia porque si no hay musica me capta la radio. Gracias por responder tan rapido.
Oct 21, 2011. 5:23 PMecopp96 says:
no, use cable comun. puede ser eso lo checare. Gracas por el consejo.
Oct 23, 2011. 4:30 PMecopp96 says:
cambie los cables yy elimine algunas conexiones que habia en el medio del cable de empalmes que hice. Lo conecte con transformador de celular que da entre 4.5 y 9.5 volts y 8000ma y la interferencia se fue que podra ser?
Oct 8, 2011. 9:47 AMmgingerich says:
Does it matter what kind of transistor as long as you use NPN?
Oct 11, 2011. 10:32 PMtobster9103 says:
one of them is a NPN and the other is a PNP. It does matter. Q1 is NPN and Q2 is the PNP, you can tell from the schematic. Hope this helps out.
Oct 3, 2011. 1:46 PMblinkyblinky says:
I love it.
Sep 30, 2011. 3:50 AMsunnykhaskheli says:
Hellow im new and 13 years old, so i dont know much about Q1 and Q2 whats the mean of this
1-40 of 274next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:brunoip(Bruno Games)
Robots and video games...
