3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rechargable pocket sized amplifier
Step 3Making the circuit
Making the circuit
Is a really easy to do circuit.
First of all you gonna need to do the PCB.
You can do it with ironing method using the pdf or using the way that you allways use.
The PCB is designed for the BC transistors so if you what to use the 2n3904 and 2n3906 transistor be careful whith the terminals.
R1: 4k7 resisor ( yellow violet red)
R2: 1M resistor (brown black green)
Q1:  BC548 or 2N3904
Q2: BC327 or 2N3906
C1: 10uF capacitor
Amplifier circuit extracted from "Lupin, introduccion a la electronica".
49 comments
1-40 of 49next »
May 24, 2012. 9:28 AMBegradoo says:
I built this little amp and it works great considering its simplicity and low voltage. It drives cell phone speakers especially well.
Would it be possible to use a more robust set of transistors and higher uf caps and increase the voltage? Maybe drive a little bigger of a speaker.
May 23, 2012. 7:17 AMmamajr96 says:
How exactly do you make the PCB, understand you need to print the PDF, but what exactly do you do.
Feb 1, 2012. 12:13 PMlukeD says:
great ible *5
Can I hook up 5 big speakers to this amplifier?
Oct 3, 2011. 1:46 PMblinkyblinky says:
I love it.
Sep 30, 2011. 3:50 AMsunnykhaskheli says:
Hellow im new and 13 years old, so i dont know much about Q1 and Q2 whats the mean of this
Sep 18, 2011. 2:06 PMajervis says:
um can i use capicitors with different volts on a circuit?
Sep 25, 2010. 4:19 AMphevtron says:
ahm hallo, im new and 13 years old, so i dont know much about ufs and so on....... whats the diference between uf and μf ?
Jul 12, 2011. 4:22 AMPhoghat says:
uf is the same, just written incorrectly. Means micro farads
Apr 21, 2011. 12:07 PM-Syrus- says:
uf is how most people online write it, the correct and scientific way is μf.
It stands for micro Farad.
Micro is 1 x -10^6
Farad is in F and stands for capacitance.
Sep 25, 2010. 12:40 PMphevtron says:
thnx :D :D
Jun 2, 2011. 6:29 PMsebastianvdm says:
como conectas el cargador? la pata del medio es negativa o positiva?
Apr 8, 2011. 3:44 PMtux95 says:
when i put mine together the audio just comes out as scratching but in rythme to what ever song is playing.
would that be an issue with my connection?
Apr 21, 2011. 3:35 AMrobot1398 says:
your some metarial should not be working properly
cap must be broken
or the transistor must be broken
check if any wires are short
R
Feb 26, 2011. 12:38 AMrobot1398 says:
in the circuit digram what dose"in" mean
is it audio in
Feb 27, 2011. 1:00 AMrobot1398 says:
thanks
good project
Nov 17, 2010. 4:02 AM955josiah says:
if i use 4.5 volts of battery is there any possible to make it louder
Oct 8, 2010. 5:58 AMwobbler says:
Great project! You could add a solar cell or two from a cheap garden light to the back and make it solar powered too.
Sep 27, 2010. 5:36 AMphevtron says:
ahm sorry again but... i found a bc 548b and a bc 548c, can i use them ? does the b or c matter ?
Sep 28, 2010. 7:12 AMLenny24 says:
The B and the C just stands for the Current gain.
B should be around 400 and the C around 500, i think.
Maybe, if you use the C-Type, it is a tiny bit louder, or so.
Aug 10, 2010. 5:59 PMC_KNOW says:
Hey Bru, dumb question, but working on this, my first project, need to know the bottom "wire" from power source to speaker is it connected to rest of the circuit by that inch long wire(because its missing a blob)? and also the "IN" that's the audio source correct? thanks for this can't wait to get it hooked up
Aug 10, 2010. 6:58 PMC_KNOW says:
Great exactly! Gracias
Jul 27, 2010. 6:41 PMcoilsinamotor says:
wow thats soo easy so easy that even i can do it thats for the instructable!
Jun 4, 2010. 12:11 PMpyrohaz says:
If you put the resistor R2 between the transistors collector and base, you will most probably increase the sonic quality due to some negative feedback :) Also, it will help with biasing as battery decreases :D
May 23, 2010. 10:04 AMalex12349 says:
what is the battery usage pattern i mean how long one complete recharge lasts w/o any distortion?
Jan 25, 2010. 8:31 AMarvi9ster says:
 will it work if i use 1bc transistor and the 2nd one the 2n3906?
i tried assembling it but nothing works!
could you suggest as to what the problem might be?
thankyou
Sep 29, 2009. 7:40 PMpancho del rancho says:
can u change the 10 uf to a higher 1 to make it louder if its possible at all
Oct 1, 2009. 12:14 PMmynameishamm says:
How many *WATTS
Oct 1, 2009. 7:58 PMpancho del rancho says:
i think one the 5v is 3W and the other im not sure
Sep 30, 2009. 2:50 PMmynameishamm says:
How many volts? SORRY for horrible english.
Sep 30, 2009. 10:01 PMpancho del rancho says:
um 1 is 5 volts and other im sure is like 18
Jul 15, 2009. 12:45 AMtiekietemboe says:
How big must the speaker be, and how much volts?
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:brunoip(Bruno Games)
Robots and video games...
