3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rechargable pocket sized amplifier
Step 4The switch
The switch
The switch selects betwen the on mode and the charging mode (off).
If you won't make it rechargable and you will use common batteries just use a normal on/off switch.
5 comments
Oct 8, 2010. 6:15 AMwobbler says:
Great project. You don't actually need to use a double pole switch. You only need to switch one of the batter connections between the charger and the pcb, the other connections can then be commoned. In your diagram, leave the switch in the positive supply in place and remove the bottom switch and just common those together. It will work just the same as your but only needs a simpler switch and less wiring.
You can also attach the charger wire directly to the positive battery terminal to allow you to use the amp while it is being recharged. However, it's a good idea to use a blocking diode in there to stop the battery discharging through the charger when the charger is switched off. The diode needs to be orientated correctly. If you use a cheap 1N4001, then the line end needs to be attached to the battery, the other end to the charger.
Jun 25, 2010. 3:12 PMxxInSAniACxx says:
I'm probably just stupid, but what is the dotted line?, and i don't see where the pcb connects to the circuit. (what is the pcb?)
Jun 25, 2010. 6:55 PMxxInSAniACxx says:
thnx
Aug 7, 2009. 5:37 PMNuGFX says:
What kind of switch?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:brunoip(Bruno Games)
Robots and video games...
