Introduction: Rechargeable 24LED Waterproof Flashlight
This is my first Instructable and since I don't want to be left in the dark I decided to enter the Flashlight Contest with a flashlight that is both rechargeable and waterproof.
Step 1: I Need to Start Somewhere.
I started of by gathering all the parts I needed. In this case I had most of the part except the two threaded pipe fitting and the 12V bulb. I got those at my local hardware store. I also needed a threaded end cap but they had none in stock. The bulbs are just like the regular downlight bulbs but they do not heat up like the regular bulbs, the use less energy and last longer. They will also withstand bumps and knocks better. I sourced a 12V rechargeable battery from a old RC car.
Parts List
50mm PVC Pipe
PVC Cement
50mm Threaded PVC Fitting x 2
Threaded PVC end cap Fitting
Smallish Toggle Switch
12V 24LED Downlight Bulb (They are available in different colours)
Small piece of foam
Tape, Cable ties and heat shrink
A 9V battery will also work but the the light won' t be that light or battery holder may also work if you can get it to fit and it has enough power example 8 1.5V AA batteries.
Tools
Hacksaw
Soldering Iron
Solder
Diagonal pliers (I had to look this one up, I know them as a Side Cutter - http://en.wikipedia.org/wiki/Diagonal_pliers)
File
Sand Paper
Step 2: Making Things Work
I had to make my battery fit and to do so I had to roll it up. The battery is basically 10 1.2V AA batteries joined in series. I just had to cut the plastic wrapping and tape it together. A step that I did a few months ago was to add two wires that came of the battery. I just soldered them to pins on the connector. I also decided to solder solder a wire on to the bulb instead of a connector seeing that there are less to go wrong. Polarity didn't matter since downlights usually powered by alternating current . All I then had to do is wire everything up to a switch.
I tested that everything was in working order and taped it all together.I have added a wiring diagram for those who have fialed to get there light or those who are failed to see my spelling mistake.
Step 3: Keeping It All Together
Here I am building my casing from 50mm PVC pipe and fittings.
I hacked of the threaded part and file down it down so that it will give me a flat base to put the flashlight down on. I measured my light and battery internal working so that I could shorten the 50mm PVC pipe so that access the ON/OFF switch and the battery plug from the back. Just make sure that you cut at least one end of the pipe square so that the bulb will sit straight.
Something missing from this Instructable is the threaded end cap since my local hardware store was out of stock. I will try a different hardware store tomorrow.
Step 4: Don't Inhale the Glue Vapours
This step is all about the gluing of the parts.
To avoid the shaking of the battery and damaging of the bulb from the shaking battery, I inserted a piece of insulating foam tubing around the battery up the the bulb. To make sure that there are no water getting in I added a little extra PVC Cement around the edge of the bulb just before i pressed it down into position.
All I had left to do was to glue the two end pieces on making sure that there is enough glue around the bulb to seal into into place and to keep the water out.
Step 5: Stepping Back
All that's left is to wait for the glue to dry and then I will be following the light.
Using the flash light is simple
- Unscrew the end cap revealing the charging connector and ON/OFF switch
- Turn light on or off as desired
- Screw the end cap back on the tightly to ensure that there will be no water end inside ruining the flash light.
The life of the bulb is a respectable 5.7 years but I left the flashlight on and 2 hour 15 minutes later I felt that the battery was the discharge for any real usable light.
Step 6: TheLost and Found
I added this step, the following day since I didn't have all the parts I needed.
Instead of a end cap, I had to improvise by making a end cap from a female threaded PVC fitting with a glue on end cap.
Following this step will make the flashlight more bulky, but will also add a waterproof storage compartment at the back, for example matches, a small pocket knife or pills.
Flashlight Contest
