3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rechargeable LED Safety Glasses
Here's how to mash-up a digital camera rechargeable battery with LED safety glasses.
Background:
Awhile back, I bought a pair of those clip on LED lights that attach to the arms of glasses. At first, they worked great. But after a few hours of use, the button batteries slowly died to a point that they became useless. Continually replacing button batteries, (mine had three per each light) wasn't very economical.
I had an old Canon S100 digital camera in my junk pile, (the LCD was broken). I also kept the battery charger and two Li-ion 3.6V batteries. I figured I could use the Li-ion batteries to power the LEDs.
Tools:
Hot glue gun
Scissors
Wire cutters
Soldering iron
Saw
File
Pliers
Tin snips
Hand punch
Dremel
Parts:
Safety glasses
Clip-on LED lights - Electronic Goldmine - G16248 - $2.95
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16248
Tic Tac container
26awg wire
Rechargeable battery
Battery charger
Double sided tape
Brass sheet
3/8" dowel
1/8" foam rubber
Can of Brain Toniq
Step 1Make Battery Plug (optional)
  • last photo ←
Make a "plug" that fits inside the LED light's battery compartment. The plug provides electrical connection to the contacts inside the battery compartment. Using a plug gives you the option of reverting back to the button batteries if you change your mind. For a more permanent configuration, this step can be skipped by soldering the lead wires directly to the battery contact tabs inside the lights.
Punch (using a hand punch) or cut (using tin sips) some round contact plates from the thin brass sheet. The contact plates need to be about the same diameter of the button batteries. Two contact plates are needed for each plug - positive and negative. Make sure to sand off the finish from the brass plate first.
Next, cut off about 3/8 inch length of 3/8 inch dia. dowel. Cut two pieces, one for each light. File a shallow notch on the top and bottom of the dowel plug. This allows room for the lead wires.
Using 26awg stranded wire, cut off two sets of leads, one for the left light and one for the right. The left leads should be about 15 inches long, the right about 6 inches long. Strip then solder these leads to the contact plates.
Hot glue a pair of positive and negative contact plates to ends of the dowels. Twist the leads together and heat shrink the plug for a neater appearance.
Using a Dremel, make a small notch in the light's battery compartment door. This allows access for the wire leads from the plug.
23 comments
Apr 8, 2009. 2:57 PMjpoyner says:
Do you have a link or a brand name for the LED clips that you are using. I have found a few different types, but I like the shape of the ones you are using.
Mar 15, 2009. 5:42 AMN1CK4ND0 says:
Oh cool! Another project that puts a tic-tac case to use! Thanks.
Feb 8, 2009. 3:54 AMfmiller01 says:
I suggest adding a couple of wraps of white tapearound the bridge of the glasses to: 1) support the wire running across it to the LED on the other side. 2) give the glasses a true geek look!
Jan 24, 2009. 2:30 AMdeqwer says:
I think you can focus the LED light.
Jan 22, 2009. 9:22 AMdriesyo says:
tic tac is sold in europe to
Jan 16, 2009. 10:30 PMslayercr23 says:
Is it heavy on the one side?
Jan 7, 2009. 2:15 PMFaqMan says:
Nice ible this would help in the lab alot also when you have a power shortage.
Jan 4, 2009. 3:02 PMandrewbaker says:
this brings the word geek to a whole new level OF AWESOME
Jan 3, 2009. 6:00 PMYerboogieman says:
Our old little Konica Minolta digital cam we bought in about 97 (surprisingly still works) we only had to change the batteries 4 or 5 times.
Jan 2, 2009. 4:01 PMClanky says:
I imagine the glasses would be tilting to one side. Is the battery heavy enough to do that? If it does, I suggest making a "band" that starts at the end of one arm, goes around your head, and attaches on to the other arm. Then put the battery there so it doesn't force the glasses to tilt. In any case, good Instructable.
Jan 2, 2009. 5:11 PMagdollison says:
or a counter weight
Jan 2, 2009. 3:58 PMchinchymork says:
Wow Those look really cool, a little bit and bulky though, but other wise..Good job!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:garagemonkeysan
I also go by the Instructable user name: UnknownUser2007
