Flashlight with no batteries
 by brunoip
Contest WinnerFeatured
This is a simple method to make a flashlight that will last forever.
It uses a small stepper motor to generate energy and many capacitors for keep it stored for several seconds.
Ps: I'm from Argentina so let me know any grammar mistake.
Step 2: Prepare the capacitors
The key to the lantern is to put capacitors in parallel to be interpreted as one large-capacity capacitor.
I use 40 capacitors of 1000uf 10v.
If you use more capacitors the torch will stay lit longer.
Solder four rows of 10 capacitors each one.
Then solder the rows together.
Step 3: Make the carboard case
Draw the box on the cardboard.
Trim the excess parts and fold by the lines.
Paste a strengthening in the areas where the motor will be attached.
Use double-sided tape to close the box.
If your cardboardis very hard use scotch tape to keep it closed.
Use the pdf file attached as a guide.
linterna.pdf(595x841) 3 KB
Step 4: Paint the cardboard
Paint the cardboard to make it look better and be more resistant to moisture.
Step 5: Prepare the motor connector
Solder the four diodes to the contacts of the individual coils of the motor in the male connector and a small piece of wire to pin cable which connects the common of the four coils.
Step 6: Finishing the inside
Solder the output of the four diodes to the positive of the capacitors and the wire to the negative.
Solder two pieces of wire on the opposite side of the capacitors.
Then insert it into the box.
Step 7: Leds
Cut the plastic about the size of the top.
Drill two holes for the led holders and paste.
Inset leds, solder two resistors in the positive terminals of the LEDs. Solder the negative together.
Then solder the wires coming out of the box and paste the plastic to the cardboard.
Step 8: Attach the motor
Use a zip tie to attach the motor to the cardboard box, remember to connet it to the capacitors.
Step 9: The Handle
Use a small piece of plastic and hte spacers to make a handle and paste it strongly to the motor gear.
1-40 of 77Next »
Adambowker98 says: Jun 12, 2012. 5:22 PM
Could you just use several larger caps?
brunoip (author) in reply to Adambowker98Jun 12, 2012. 6:13 PM
yep
Adambowker98 in reply to brunoipJun 13, 2012. 10:29 AM
what size would you recommend if i just wanted to use about 3 caps?
chipper35 says: Nov 23, 2011. 8:01 AM
Maybe not the prettiest flashlight in the world.....but VERY cool!!
putty1cat says: Nov 5, 2011. 12:48 PM
Thank you, your 'ible and biotele's 'ible have inspired me. I am trying to make something similar using an old hand cranked torch. I used 4x 1500uf 6.3 volt. It seems very dim unless I crank it continually. biotele used a joule thief to brighten his but I was wondering does more voltage make it brighter? So you have used 10 volt capacitors if the capacitors were lower say 6.3 volt would the led be less bright. Or is your torch dim too?
putty1cat says: Oct 10, 2011. 7:18 AM
oh, this is a really good idea! Now to figure out, how would I do this with a battery pig of a camera.
zapper067 says: Aug 20, 2011. 6:56 AM
What can we do with the processors?
anuragmahajan152 says: Aug 6, 2011. 10:23 AM
Very nice instructable. Your idea is brilliant of using capacitors and stepper motor.Thanks.
sharktooth says: Jun 10, 2011. 8:09 AM
That's Excellent...
If you don't mind, I have some suggestions for you.....
You can add some more gears (you can find them in toy cars), so that,
when you complete a round of hand-crank, the motor will complete its 20 - 25 rounds...
arikyeo says: Jan 25, 2011. 9:59 PM
I think it would be more advisable to use just 2-3 supercaps in series... They can last for minutes. Just my 2 cents ;)
brunoip (author) in reply to arikyeoJan 26, 2011. 5:44 AM
that was my first idea, but they are harder to get than regular capacitors.
n410gangwar says: Nov 15, 2010. 10:51 AM
can we use a charging circuit to charge some rechargable AAA batteries and use them in place of capacitors . They can turn the lights on for a long time.
IF WE CAN THEN PLEASE POST THE CIRCUIT THAT CAN BE USED......
brooklynlord in reply to n410gangwarDec 4, 2010. 4:29 PM
Rechargeable AAA batteries, depending on the type, will need a complex charger to prevent overcharging and it has to be at a certain voltage.
Those circuits are very complex, its not easy.
11rex11 says: Oct 18, 2010. 10:15 PM
i used some capacitors form a disposable camera the big one for the flash worked great
brunoip (author) in reply to 11rex11Oct 20, 2010. 7:42 AM
Post a pic :)
11rex11 in reply to brunoipOct 20, 2010. 10:52 PM
I made this several years ago But ill look for it i think i know where it is
johnbertquirabo says: Oct 2, 2010. 9:40 PM
does it necessary to use the same kind of stepper motor?
brunoip (author) in reply to johnbertquiraboOct 3, 2010. 9:37 AM
any unipolar stepper motor would be fine
zorba02008 says: Aug 26, 2010. 12:09 PM
can i use a stepper motor from dvd writer or hard drive ? but these motors i have has 12 pin output what can we do ?
Pyrotechnic-Robot in reply to zorba02008Aug 27, 2010. 9:27 PM
awhh sorry the spaces didnt stay. You just have i diode leading into a pin and one leading outside.
noeroldansiabox in reply to Pyrotechnic-RobotSep 24, 2010. 12:23 AM
where could i get the same kind of stepper motor used?
Pyrotechnic-Robot in reply to noeroldansiaboxSep 26, 2010. 10:40 AM
Well these types of motors are used in allot of things but probably the easiest would be a stepper motor inside a printer. You purchase larger motors but the printer stepper motors work very good.
Pyrotechnic-Robot in reply to zorba02008Aug 27, 2010. 9:25 PM
the trick to find a good stepper motor is low rpm soo a hardrive would not work too well.... to get the most power from a stepper motor is to wire it up like this Stepper input o----||| |----o----||| |----o o----||| |----o----||| |----o o----||| |----o----||| |----o o----||| |----o----||| |----o Negative Positive this takes 2 diodes per pin, the pin is connected in the center and the diodes filter the power to give you a + and - output. The ||| represents the orientation of the diode.
brunoip (author) in reply to zorba02008Aug 27, 2010. 9:47 AM
Maybe it has two motors inside, try to get the datasheet.
Regards, Bruno
noeroldansiabox says: Sep 23, 2010. 11:35 PM
where can i get a recycled stepper motor?
noeroldansiabox says: Sep 23, 2010. 11:27 PM
does these capacitors cost much?
noeroldansiabox says: Sep 23, 2010. 11:23 PM
does it really last forever?
noeroldansiabox says: Sep 23, 2010. 6:22 PM
good day!!
how long will the light last if i will be using unrecycled capacitors?
brunoip (author) in reply to noeroldansiaboxSep 23, 2010. 7:19 PM
the same ¬¬
noeroldansiabox in reply to brunoipSep 23, 2010. 11:20 PM
thanks..
noeroldansiabox says: Sep 23, 2010. 6:20 PM
good day!!
how long will thelight if i will going to use unrecycled capacitors?
matstermind says: Sep 5, 2010. 7:38 PM
what if you add a switch, them charge the caps for 10-30ish seconds. how long would the light last?
antling says: Sep 3, 2010. 8:51 PM
Nice and 2 thumbs up!
D5quar3 says: Aug 20, 2010. 3:02 PM
Just get like three super capacitors.
The Lightning Stalker in reply to D5quar3Aug 29, 2010. 4:37 PM
Just remember, they have to have low enough ESR.
static in reply to The Lightning StalkerAug 30, 2010. 5:00 PM
In this application a super cap is presented with DC mostly. While there would be a ripple current present, I'd think it would be low enough, that ESR wouldn't be a factor.
The Lightning Stalker in reply to staticAug 31, 2010. 5:13 PM
Supercaps with high ESR will not supply enough current to get full brightness from the LEDs.
skrubol in reply to The Lightning StalkerAug 30, 2010. 1:04 PM
Why do they need low ESR?
The Lightning Stalker in reply to skrubolAug 30, 2010. 4:25 PM
What I mean is that some of the super capacitors have very high ESR. The ESR just has to be like something less than 2 ohms.
.Unknown. in reply to The Lightning StalkerSep 3, 2010. 3:26 AM
Use some sort of joule thief like this one. It draws much less than 20ma, even with 2 LEDs on, and the LEDs are pretty bright too.
1-40 of 77Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
