3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Flashlight with no batteries
Step 9The Handle
The Handle
  • last photo ←
Use a small piece of plastic and hte spacers to make a handle and paste it strongly to the motor gear.
8 comments
Aug 6, 2011. 10:23 AManuragmahajan152 says:
Very nice instructable. Your idea is brilliant of using capacitors and stepper motor.Thanks.
Nov 15, 2010. 10:51 AMn410gangwar says:
can we use a charging circuit to charge some rechargable AAA batteries and use them in place of capacitors . They can turn the lights on for a long time.
IF WE CAN THEN PLEASE POST THE CIRCUIT THAT CAN BE USED......
Dec 4, 2010. 4:29 PMbrooklynlord says:
Rechargeable AAA batteries, depending on the type, will need a complex charger to prevent overcharging and it has to be at a certain voltage.
Those circuits are very complex, its not easy.
Sep 3, 2010. 8:51 PMantling says:
Nice and 2 thumbs up!
Aug 29, 2010. 10:32 AMxarlock667 says:
Ummm.... I have an off topic question. Could this be used as a hand cranked stun gun? Seems to have enough capacitors wired correctly, just remove the lights and replace with two electrodes? Home made self defence tool for cheap?
Aug 31, 2010. 7:25 AMbarbsman1 says:
No.. it couldn't be used like a Standard stun gun. Stun guns have inductors as well as capacitors, which creates a sort of "tank circuit" when combined with the internal circuit and use two contacts to short it out across target.. However, removing the LEDs and placing two contacts out the front could be used to deliver a discharge of the caps. Don't know if you have ever picked up a charged cap before, but it hurts when it discharges across you. I will see what I can come up with for a Make-Your-Own stun gun.
Aug 30, 2010. 4:05 PMstatic says:
LOL.. You gave me this image of a victim chasing after their attacker while frantically cranking away at their stun gun. No way are these salvaged capacitors rate for the voltage rating that would have anyone fell the discharge.
Aug 31, 2010. 1:52 AMxarlock667 says:
I have heard that before actually, but what most do not realize is that it is the amperage that really counts. 1000uf by itself is not much, but he has around 40 in this setup. Make it 100, and suddenly you have a respectable zap. Hand cranking should only be considered if you are in BFE and have no batteries. Like a soldier in the field, or a camper. Not ideal but perhaps a nifty fallback.
Aug 29, 2010. 11:45 AMthe judge says:
the way it's set up now, no. stun guns have at least 5000 volts. but if u charged them in parallel and discharged in series, that might work, but im not sure that would be safe.
Aug 28, 2010. 11:01 AMprakash.be2005 says:
great machi....
Aug 27, 2010. 7:58 PMlivntoasty says:
Very nice! I would rather do it your way then buy a kit. Looks like more fun. Thank you :)
Aug 27, 2010. 2:58 PMGrotBox says:
Brilliant. I like the fact that you've made it completely from trash and especially that you've made your own box.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:brunoip(Bruno Games)
Robots and video games...
