3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recirculating Hydroponics
This unit allows for long term growth of large plants. There have been several hydroponic posts here in the past, but they all shared the limitations of either small plants or short term growth. This unit can grow a large plant practically indefinitely.
Step 1Parts
You will need
Two stackable containers
A small fountain pump
1/2 inch pvc pipe , two elbow fittings, a threaded end cap and plug.
Clear vinyl tubing to fit your pump
zip tie
plastic window screening
perlite
plants
hole saw and drill
and anything i forgot.
20 comments
Jan 2, 2008. 3:18 PMCool-fool says:
Nice! Is there a way to do this without PVC?
Apr 13, 2010. 7:18 PMDavilyn says:
Did you ever find a system made without PVC?  I am a Hydro farmer and use The Urban Farm (www.theurbanfarm.com) which is for bigger plants like indeterminate tomatoes or watermelons but am still looking for the smaller type for lettuce and such.
Mar 31, 2008. 1:31 PMchriscc63 says:
this looks pretty awesome, I wonder if there are any others this simple. I would like to add to genius by suggesting a solar panel to run the pump.! I am unfamiliar with the requirements of these systems but does the pump have to run 24/7 or would a solar panel running it all day be enough?
Aug 18, 2008. 11:11 AMjeff-o says:
I imagine that the pump would have to run 24/7, otherwise the water would drain out of the perlite (leaving the roots dry) after only an hour or two.
Feb 4, 2010. 3:48 PMToastalicious says:
 save power by adding a timer to run it for 30 minutes every hour or two then.
Feb 4, 2010. 6:09 PMjeff-o says:
that'll work!
Oct 8, 2009. 2:18 PMlqdtrance says:
I would also like to know TheDeadMethod's question.
Apr 20, 2009. 7:42 PMgsteiner says:
The roots should be fine overnight. My understanding is that plants don't take in water at night, and without the heat of the sun drying out isn't an issue. I have a makeshift aeroponics system I built into a large 30 gallon garbage can with a 10 second spray every 15 minutes or so. I shut the system off every night when the sun goes down and the plants are doing just fine. I would imagine that perlite is going to hold more solution overnight than just roots hanging out in the air.
Nov 3, 2008. 9:43 PMTheDeadMethod says:
Would stacking the containers and drilling through the bottom of the upper container through the top of the lower one (so the holes line up) eliminate the need for the lip? It seems you only need it because of the odd grooves in the bottom of the buckets.
Oct 31, 2008. 9:23 AMtabletopphoto says:
as long as the roots don't dry out, you are fine
Aug 17, 2008. 10:14 PMpuffyfluff says:
Wow. I'm building a greenhouse, and I was planning on using hydroponics. I think I'll use this.
Jun 17, 2007. 4:26 AMtubesystem says:
Less is more. I think you should put the tube inside the box. Like me. Any way good job.
http://www.huatan.net/bbs/1155285953/Mon_0703/87_52012_bb1aeee9a4a90be.jpg
See my job:http://www.huatan.net/bbs/read-htm-tid-61483.html
Aug 12, 2008. 8:42 AMbob.smitty says:
looks like an awesome project... but i can't read any of it!
Jul 10, 2007. 3:42 PMbqbowden says:
(removed by author or community request)
Jan 5, 2008. 2:04 PMbhsx says:
yes, this is very similar to my simple aquaponics system which I'll get up here shortly. It's been in use for well over a year with no issues.
Aug 13, 2007. 9:13 AMRed_Icculus says:
It sounds like you are flooding the medium all the time. Perlite has a tendency to get waterlogged. Have you had any overwatering problems?
Aug 13, 2007. 7:58 PMRed_Icculus says:
That's awesome. The most I heard of flooding was 15 minutes every 4 hours. Being outside in the heat must make the difference. Glad it works for you.
Jun 12, 2007. 3:14 PMhamrad says:
I was just reading something that trebuchet03 posted about hydroponics (I originally found his post while searching the subject). I am just learning about this and he suggested I send you a email/post. I live in Clearwater Florida and would like to start some cherry tomatoes (I know it is late in the season) but via hyproponics instead of in the ground. Is it too late to start tomatoes and if so what else could I used to get into this form or gardening? Thanks for your time, hamrad
May 20, 2007. 6:49 PMmeddler says:
I have wanted to try a hydroponic system for a while, but was a bit imtimidated by it. I think i'll try this
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
