Reclaimed Driftwood Bench
4,061
117
22
Posted in WorkshopFurniture
Introduction: Reclaimed Driftwood Bench
About: We are designer/builders making cool stuff and cozy mod tiny cabins from recycled materials. We have a bunch of adventures coming up so please follow us if you would like to see more recycled and energy eff...
This stationary bench was designed for an entryway as a great place to set down groceries or change out some muddy boots. It brings instant character to a space but also feels modern and simple and was very easy to build using only a drill.
Step 1: Gather Materials
Just a handful of materials are needed.
1 perfectly sized piece of Driftwood
2 ea 12" long 3/4" Threaded Galvanized Pipe (you may need longer or shorter depending on the thickness of your driftwood)
4 ea 3/4" Flanges
2 ea 'L' Brackets about the same length of your driftwood thickness
24 ea appropriately sized exterior grade screws (we used 2" #8 philips head screws)
Step 2: Sourcing Appropriate Driftwood
Obviously finding your driftwood is a challenge, but maybe not as much of a challenge as you might think. Naturally formed driftwood actually plays many important role in the Eco System by protecting beaches from erosion and providing habitat for a variety of species so please don't just start removing anything.
However parts of docks and piers are also constantly finding their way into oceans and beaches. These often times have harsh chemicals or toxic paints that should be removed from beaches. Look for artificial cuts, painted areas and the tell tale surface cuts of pressure treated wood.
If you find one that is close to the size you need you can always cut it down. If its too large to carry I've been known to mark its location and kayak back during high tide and drag lumber back via ropes.
Be aware of private property and beach access rights in your area.
With any luck you will find a piece that has been dashed around by the waves for awhile and has the appropriate thickness, character, smoothness and length.
There are also recycled house parts stores and even reclaimed lumber stores where you may be able to find what you want. This basic plan would work with any sturdy piece of wood so think creatively.
Step 3: Tools
The only tools we used for this project were a drill with a Philips head bit, you may want a tape measure, drill bit to pre-drill holes or maybe even a saw to cut down your wood.
Be extra careful when handling reclaimed driftwood. Nails or hardware may be hidden and some older boards contain harsh chemicals and paints. Wear a mask if you're doing anything that might create sawdust.
Step 4: Assemble Legs and Mount
The legs for this are really easy. Just assemble the the galvanized pipe to the galvanized flange and screw them into the driftwood. This was a little tricky because our driftwood was a little lumpy and not regular shaped. We moved them around until we found an area that seemed level and flat. We screwed them in at this time but didn't tighten them all the way so that we would have a little wiggle room later to adjust things.
Step 5: You're Not Done Yet!
You can pick up the bench and place it where you will like it. But it will still be wobbly at this point even if you screw down the flanges. We used 'L' brackets by simply holding them up under the bench where they would need to be mounted and then removing the bench while still holding the L Bracket against the wall. We were able to calculate where our support beams were on the interior wall so were able to mount these very securely. Using this method will give a lot of structural support but the hardware can't be seen when the bench is in place.
We then put the bench back in place, made sure it was level and then screwed it all into place, making sure that we also attached some screws through the 'L' brackets into the bottom of the driftwood.
Step 6: Have a Seat!
We are not sure what to call this style, maybe Rustic Modern? Or Charming Contemporary? Whatever you want to call it this is a very solid and practical bench that will give instant aged character to your entryway or anywhere you may need a built in bench.
After this project we ended up making a matching Reclaimed Driftwood Coat Hanger so make sure and check that out too!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    22 Comments
    Hi, thank you we just noticed your comment from a year ago! How lame are we?!? just posted a matching coat rack so check it out.
    https://www.instructables.com/id/Reclaimed-Driftwood-Coat-Hanger/
    Sorry, we are slow posters but just saw your comment and thank you. We just posted a matching coat rack so check it out!
    Did you have to plane or sand any rough spots? or< because of being driftwood< it"s already perfect?
    with any luck you can find pieces that are perfectly sanded by the sea. We actually found several on this day so maybe I will make an instructable on shelf building or something soon.
    Thank you for the info. I'm not asking you to disclose any 'secret hunting grounds', but I would love to know the general area in which you live. I love the ocean, but I'm landlocked in the High Desert of S.W. New Mexico. I'd love to visit the area some time, . . . and walk the beaches. Thank you.
    Thank you! Are you aware there's a book on making driftwood furniture? Might give you some new ideas. . .
    If it's an e-book kindly email me: chrisjlionel@yahoo.com
    I have a hardcover copy-- I do not know if it is available as an ebook. You might find a used copy on ebay or somewhere. . . ..
    Sounds great, I will look for it at the library. We use reclaimed driftwood a fair amount in our designs.
    Ah, I kept searching and finally found my copy. It's called "Driftwood Furniture" by Derek Douglas. Lots of neat ideas. Enjoy and happy hunting!
    We are in the Puget Sound region, its difficult to walk out the door without tripping on driftwood. We actually have some problems with the big logs washing up under our neighbors house, she lets us have them if we help her haul them out!
    Continental Drift - like that could be the name for the style.
    That is actually a great name! I'm going to try it out...
    Love it, this industrial combined with authentic materials style.
    thanks, we are not even sure what to call it but that's our style in a nutshell
