Introduction: Reclaimed Firewood Ambiance Light "Ardenne"
Picture of Reclaimed Firewood Ambiance Light "Ardenne"
How to make a nice ambient light out of firewood.
Step 1: First Let Me Show You the Idea.
Picture of First Let Me Show You the Idea.
This is a multi movable piece of light. you can set it like you want and regulate the amount of light with the flaps. in the last pictures i even put some extra candles on it to add something extra. the sky is the LIMIT. check out how it is build!
Step 2: Videobuild
The video shows the build with extra speed so you don't get bored of the repetetive work.
This is the firelog it all started with. A nice piece of firewood from the Ardenne in Belgium.
Step 3: This Is What You Need
Picture of This Is What You Need
-Gu10 socket. (reclaimed from defect nighstandlight).
-Gu10 2 or 3watt led (so it doesn't get too hot).(new).
-extensioncord with or without switch (mine is an old cord of broken vacuumcleaner).
-10mm steelpipe and some washers (ebay is the way :D).
-tools,silicones,glues,sandpapers,....
Step 4: Start
Picture of Start
we cut up the block in the amount of pieces we want. Dont forget the minimum buildhigh for the led AND socket the fit in!
Next cut the pipe to average length. sand it down nicely.
Step 5: Next
Picture of Next
We drill the holes for the pivot and lightspot
10mm pipe=10mm hole for pivot.
my light is about 35mm, so i took an american forstnerbit that is a bit bigger.(for all holes)
Step 6: Next Next
Picture of Next Next
make room on the bottom to fit all wires and sockets. dont forget to drill a hole straight trough so the GU10 cables can get to the bottom of the light where the extensioncord sits.
i put some rubber feet on it to protect the surface.
Step 7: Next Next Next ;-)
Picture of Next Next Next ;-)
connect all wires, makes sure you do this right. next i use hotglue to get it sticking to the base AND to isolate the cables.
the GU10 socket is put in with some rubbersilicone since hotglue and temperature arent that great ;-).
just don't forget the 2(or 1) washer or any other spacer to put between each slat so the can more freely and have some space to let the light come out..
now you are down and can play with it.
i might forget some steps, but this is a real simple project that any handyman could do with ease. (or a great learning for the ones who are just stepped into it.)
have a nice time!
happy greetings,
Jörgen
RichardBronosky (author)2017-03-02
I love this. I'm going to make this with my daughters. But instead of drilling all the "light spots" with the same forstner bit, I'm going to let them cut freeform shapes on the jigsaw table. Then you can cast amoeba shadow puppets on the ceiling.
that would be a nice idea friend! it can come out real nice!
Hamids (author)2017-03-04
very nice art , have you know any links to gallery for such beautiful art made things
JörgenBörg (author)Hamids2017-03-05
sorry,mate, most stuff i make comes from my mind. instructables is a nice place to find stuff like this haha. well, actually true, i love alot of stuff here.
CoderPranav (author)2017-02-23
Looks amazing!
JörgenBörg (author)CoderPranav2017-02-24
well, thank you twice :D
CoderPranav (author)JörgenBörg2017-02-26
xD
thx mate
Darth Fisticuffs (author)2017-02-24
Did you sand each piece slightly concave so light can show through? Or are they just flat?
just flat. the only sanding was to make them less rough and to remove sharp edges. the spacers make sure the light can get through it. and because of the light color wood it makes the like easier to reflect.
tcallen (author)2017-02-23
I am concerned about heat/fire potential. What is the risk level?
Darth Fisticuffs (author)tcallen2017-02-24
I use LED GU-10 bulbs in my kitchen. They don't get anywhere close to as hot as standard incandescent bulbs (and they use a lot less power!)
sgbotsford (author)tcallen2017-02-23
3 watts. Not an issue.
JörgenBörg (author)sgbotsford2017-02-24
jup, indeed. the light i bought is never too hot to touch, so the risk of fire just as high as any other storebought light. and the electrical connection is stored in hotglue on the bottom, so no risk of electrical fire too. friendly greetings, Jörgen
Tuomas Soikkeli (author)2017-02-24
Wow. This is great! Why i have missed it. Best "log lamp" i have seen!
Hope you have seen many loglights then hahaha ;-). you probably haven't seen it because it was just online, and i didn't steal it of an existing model (but you never know if somebody has made this before) friendly greetings, Jörgen
AmirulL1 (author)2017-02-23
beautiful!
JörgenBörg (author)AmirulL12017-02-24
thank you very much :-)
MichaelM772 (author)2017-02-23
I like this. You can see it has an LED in the bottom piece and the candles were just placed on a few open spaces. At first I thought this was made using candles. It can be confusing until you look through the steps.
JörgenBörg (author)MichaelM7722017-02-24
haha, ok, didn't notice that :-). i would not put a tealight into the base.haha. tealight was actually an extra that i found out when the light was actually put in place. It's a oable option, and who doesn't like options right ;-)
Gadget93 (author)2017-02-23
Cool.
JörgenBörg (author)Gadget932017-02-24
thanks for checking it out :-)
Looks amazing!
CoderPranav (author)CoderPranav2017-02-23
Darn it...posted twice by accident..
About This Instructable
9,320views
203favorites
Bio: Electromechanic with a woodworking hobby who interesses in random projects...
More by JörgenBörg:Happy Robot Mascotte (stopmotion Film + Build)My Shop Aircleaner (reclaimed Wood and Motor)Supereasy Cheap Pockethole Jig
Add instructable to:
