Reclaimed Oak Trestle Table
Published
Introduction: Reclaimed Oak Trestle Table
This table was made completely from scratch using a single huge oak beam reclaimed from a 125 year old barn in northern Wisconsin.
Step 1: Making Boards for Tabletop
After actually finding, hauling, drying, de-bugging and cleaning a 125 year old white oak barn beam, I cut it to approximate length using a Prazi beam cutter. I then bookmatch saw it on my sawmill into 2-inch thick boards.
Step 2: Plane, Join and Glue
After running the boards through the planer I joint the edges using my festool track saw. I then used a biscuit joiner and glue the boards for the tabletop together.
Step 3: Square the Edges and Sanding
I squared off the edges, again using my trusty Festool track saw. I then began the arduous process of initial sanding.
Step 4: Fill Voids With Epoxy
Once I have an initial rough sanding done, I fill all the voids with epoxy. Then sand and sand and sand and sand some more.
Step 5: Finishing the Top
I use an equal mixture of BLO, Tung oil and Polyurethane to finish the top. I ended up doing 7 coats, sanding with 500 grit between each coat.
Step 6: Base Build
I used a simple designed but spiced it up with a mix of color and raw wood - from the same beam the top came from.
Tables and Desks Contest 2016
Second Prize in the
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    26 Comments
    Congratulations on the win in the Tables and Desks contest!
    what kind of epoxy do you use to fill holes? and does it stain if you were to apply stain?
    I just use a clear two-part epoxy resin, the kind that you'd use for a bar/table top. My trick is to use an empty squeez ketchup-type bottle to fill the voids. You can get a six pack for a few bucks. Makes it easier to control and less mess. As far as staining, my personal preference is to never stain such beautiful wood.....but, if you want to, you can purchase special powders that you can mix directly into the epoxy.
    Nicely done! I made a similar table out of clear pine nearly 40 years ago. It has since been passed down to a Daughter. You have created an heirloom that will stand the test of time.
    WOW!!! again WOW!!!! very nice
    Really beautiful! Reclaimed wood is the way to go whenever possible and I appreciate the many hours of work and skill you put into this project.
    Beautiful! I really like trestle tables because they don't have the legs in the corners to bang into.
    Oh, this is gorgeous! There's really no place for something like this in my little round house, but if my situation changes, I want to build this! Beautiful work.
    Thank you! In my opinion there is nothing more beautiful than turning something you saved into a functional piece of art.
    Gorgeous! you got my vote. I have some old barn beams that we had to replace in our 100+ year old barn. I don't have enough to make such a large table but may do some smaller end tables based on this ible. Thanks
    Thank you! I saved up forever to get a small sawmill to be able to build just this type of table. Ive used siding boards in the past but there is nothing like opening up a beam for the first time!
    Very nice. How do the table top and legs piece together?
    Thank you. Pretty simply, once the top was finished I screwed 2 boards, that match the base, into the bottom of the table top. These prevent the top from moving too much due to temp and moisture changes. I stacked those boards onto the top base boards and screwed them together from the bottom. Nothing fancy but gets the job done and makes it easy to disassemble.
    Super Sache aus alt werde neu sehr cool
