Record Lampshade
Record Lampshade
This is a mash-up of a couple different projects: My pop-up pyramid and the classic vinyl record bowl idea.
If the low heat makes the vinyl easy to work with, then why not apply the geometric cuts to get some extra height, right? And then, why not, slap a light bulb inside of it.
Sure, let's do it.
Step 1Mark the Record
Mark the Record
I'm not using any computers for this one and definitely not a laser cutter. I heard that someone at IDEO passed out from the fumes while trying to laser cut vinyl so I'm hoping to avoid that mistake.
The cuts here are all about circles with gaps in them. Here, I'm drawing eight lines across the record, four for each orientation of the cut circles.
Also, I picked records based on them having songs that have equal length and thus regular circles for the dead air between songs. Why not use the medium to its advantage, eh?
28 comments
Jun 4, 2007. 9:44 AMjessyratfink says:
I love this. Now I have a way to make some cool lamps for the apartment. We're drowning in records at work. I think this could be made even better by painting the lamp. I think white would be gorgeous, or perhaps a light blue or green. :D
May 5, 2009. 12:11 AMoklacalit says:
I mean this is cool and all, but why did you have to do it to heart and the boss? I can understand film soundtracks, but those are a couple great bands.
Jan 19, 2011. 8:27 PMcambridge37 says:
agreed!
Sep 25, 2009. 9:25 AMValche says:
ewww :P
Dec 13, 2006. 1:23 PMmdomino says:
okay _ i am not trying to be rude, but does anyone else find this thing a touch unattractive. gosh, feel like i am talking trash on someone's sister...
Dec 14, 2006. 3:46 PMhaptotrope says:
You should tottall drill holes in the hanging strips and hand strings of glass beads (or plastic if the wattage is low enough) --- shiny!
Jul 13, 2010. 12:42 PMTabbyDeAnne says:
GREAT IDEA!! BOTH THE LAMP AND THE BEADS! LOVE IT!
Dec 13, 2006. 4:41 PMJesus10555 says:
Ok, In all honesty, I think it is a great Idea, the only thing I would change if I were you, (or if I make one) is to cover the bulb, so that it is not directly visible, because it is too bright. I think it looks great though :) just the bulb needs some hiding
Jul 13, 2010. 12:45 PMTabbyDeAnne says:
Light bulb paint might work or wax/rice paper if the bulb is an LED.
Feb 1, 2007. 4:40 PMgrannyideas says:
I think if you made the cuts smaller (shorter) at the top it wouldn't drape down so far and it would cover the bulb more. just an idea.....
Jul 13, 2010. 12:44 PMTabbyDeAnne says:
GREAT IDEA AS WELL!! I WILL TRY THE SMALLER CUTS AT THE CENTER AND ADD BEADS!! THANKS!
Jan 24, 2009. 11:00 PMStarrsWife says:
I am SOOOO thinking side table with this as the base!
Dec 3, 2008. 6:42 PMShut Up Now says:
i was wondering.. it would be awsome if you took a decorative glass bowl and laid the heated record over it to get the curves. maybe put a layer of some lubricant (oil) so it could be separated.
Dec 20, 2007. 8:04 PMincorrigible packrat says:
You fiend! Wrecking a perfectly good Heart record.
Oct 11, 2007. 12:44 PMapartment42b says:
Neat! If I make one of these I don't think I'd stretch it *quite* so far... that's an interesting look but it looks over-extended somehow, like it's straining to break (even if it's perfectly stable). Oh! I bet you could do two of these sort of gently stretched and attatch the wide ends together, so it'd be kind of like an open chinese lantern. You could either cut more of the bottom one out from the center or just leave it as is to cast a circular shadow down below. Or make a giant globe-ish shape with several, hee hee :3
Jun 25, 2007. 9:43 AMkatz says:
I wonder if you can make this with old CD's and DVD's? Or do they need different melting technic? This would be very shiny!
Jun 28, 2007. 4:14 PMlatobada says:
they don't quite melt like that, and i'd imagine the cutting would be hell, seeing how small CD's are. but they also are think little buggers if you think about it.
Jan 25, 2007. 10:56 PMILOSN says:
OH WOW. What a nifty idea!
Dec 13, 2006. 3:37 PMPetervG says:
Im scared to do it because it might smoke or explode or something crazy like that.
Dec 13, 2006. 5:34 PMPetervG says:
Maybe say 200F because I wasn't sure if you meant C or F
Dec 12, 2006. 1:50 PMzachninme says:
Very cool. I wonder if you could melt it with the heat of the lamp?
Dec 12, 2006. 2:32 PMPetervG says:
That sounds a lot easier. Just get a really inefficient bulb and over time watch it grow. This sounds like some I will do, I just dont understand where to cut, ill go read it again.
Dec 12, 2006. 8:45 PMzachninme says:
Hmm, that would be a cool gift. One that you can tell if it wasn't used :-P It starts off really stupid, and gets cooler :-)
Dec 12, 2006. 2:34 PMPetervG says:
Ohhhh, I get it now.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1328
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
