Recording HD (720p) Video in Max 7
Published
Introduction: Recording HD (720p) Video in Max 7
About: Too much television as a kid.
So you want to record your Jitter video output from Max 7 patches running on OSX in HD quality. In fact, let me make that more specific: you want your Jitter movies to be editable in a program such as Final Cut Pro X and viewable via QuickView in the OSX Finder. This is quite an understandable requirement if you are making a video art project using max/msp/jitter which needs some editing and post production. In this Instructable we'll edit an existing patch, but this works just as well for your own jitter patches where you need to generate 720p video.
Step 1: Record the Output From an Existing Patch
As an example, let's record the output from the Cycle-delic patch (see image). Open that one in Max 7.
Step 2: Make Sure Everything Generates 720p HD Video
In the example patch, the jitter matrix is restricted to 320 x 240 video. Although we can blow this up to 1280 x 720 HD, it would look quite pixelated. So we need to make sure all the parts that reference this small 320 x 240 format are changed to 1280 x 720. Most of it is in the [p stuff] object. After you've edited that one, it should look as the image in this step.
Step 3: Adjust the Center Pictslider
The second pictslider, labeled "Center", needs some different parameters now that it has to handle HD video. Set the value at Bottom to about 730 and the value at Right side to about 1290.
Step 4: Add Objects to Record Our Output.
The only output of the [p stuff] object is the jitter matrix we want to record. So this goes into a new [jit.record] object with dimensions 1280 and 720. Make sure the engine attribute is set at 'avf' and the codec to 'prores422'. We also need to add two messages: [write 25.] to write a movie at 25 frames per second (or change that to your desired framerate) and a [stop] message to stop recording video.
Step 5: Record Your Video!
By clicking on the [write] message box, a dialog opens where you can tell OSX where to save your new movie and under which name. You may notice that Max gets a bit more sluggish from generating video of this high quality. After the recording is done, you now have a prores422 Quictime movie in 1280 x 720 quality, ready for further editing.
So why the prores422 and not 4444? It appears that the latter can't be viewed via QuickView in OSX (i.e. hitting the space bar on a selected file in the Finder). If this is not a requirement for you, you can of course choose whatever codec you want. However, prores422 is easily good enough for silly art things rendered in jitter. On the last step, I will post the patch in Max clipboard format.
Happy patching!
Step 6: Max Code (File - New From Clipboard)
----------begin_max5_patcher----------
4605.3oc6ck0aiajD9Y6eEbDlMHYhsRexifMASlDDr.Kv9RdLHqAkDkDioH4
RR4wSxl8291G7ThGszHRQZX+fbyljMq9qpt5qpp9Ou8lYKBd1Idl12p8qZ2b
yed6M2HxhmwMoWeyrc1OuzyNV7XyVFramiexr6j2Kw44DQ9QNKChVo45qYf.
gZ+ieJ6I72uy02yIQ75vhLC1mjkKHM2P6jkac827.qvRjDkAPeN3NMJV7OHE
v+Gh8q1uk9RtqDe+fE+98HZ1GMN4SdNh7mwy3ut8V9O2oXcbmSbr8FmipieL
xMwQCQmWacCUacC1bcSGhk0Mp3ehZHBUeUCix9lxxN4SgNxRY1r7m+yqV667
Q1W5nJ8u6lLOk4BQl.N6U68N9ab8czreZs16WFrxYoVXTPjSLAgNA9NpYrgZ
H3z5DADgLaEbPfFAGF0+vN6jH2mmcWuCUgZwI6WutVDHSFecfeRr6eH91P3b
KLw.CaUxYq6pUN9cHKkhWDcKw+PsAWDpJvU9axoXe6cRz5Ghbs8poUVYJyIJ
E5RwNVQ3547jSTraP45wMyrCCKk8MkdENf+6AhBx3t7rb8kYAxyJx4I2CKVV
4FwvmDF3rORReOapOqnXXBrQ96cEuiLSFq+1rBLCRI.AjZHPTSXJvRJvTlTx
lkAdRR5W0fBMTk+o7C5Er7QmUkI9YAgN9t9grlMLEp1Io0h7auxYs8dujGpH
wvIoZt+Z6kNM9x0x7tY1lH2UA9bhnBOgmc1miUonR8tkqLhmv2NrlWlIdwvu
FtYLqRtOdgcDmksPJ4fxtYRPfW0ak+ddNqSRucnqu+AnXRPXy2Lxcy1Vd2EA
ratqsxVbm3G16Ku6CLU.IODa+TUzNw1yKUmP0h+YaeWV6ImDWIK.AxuoiuMq
htMdYTfmWk5q7NOUycVwj1W57Q2UIaEenxBCrG2MLSHZVNWdk6Fm3jp4kXuI
tZNG0Rlk09EosleHwYWnGqVT8ApLzgxMcKq8rR9soE83Ncj5gzVu3QMh1xs1
Q48+T9Upqalb0VG1rnCEvM2EUSpckMOv.YKdcxgpcOpmJXYZW0dqZWMbc8mc
SVeZoJ2NSNjj.UBtqcDcMAaHKgpUL1P.XzreaD1.MTWKka1.SuzXvh8LcD9k
+RUz5ypHlHLEeGKEhBrL4IHXH1.WsOfVQONzwFP0g8l.laZw+EXUaYc7fEjz
Gqnd7TJpZ3PVR89.qrwaWcT2GxffVsJWuv1eSUo49QdsCMJAgGpIQ68r7dm1
6ex1igMzFkzQWGEKHCYCD4DEZSwBzbRoXoEFEa7PrANrRKHTY07pi5v1QcbJ
dSE+SNV5VQciVQ8qONWclrUA56UVZ+xguTgtHDVfrPyNwW8QN91hbbrimFaL
T8.H2gpCLQJ2JUgPL5Djocq6dTnzXOq+88JoTfM2ucoCMkgPrWmQ+2w+4c4o
9l7TecdJA6JK2c4IuuH4eKOE6KWj1947z1KJ9Z1Osob9qb4qMP50uoBc8lBx
4M2Wjr3y8E4o9u4o924o9e4o99uOO4e+uW71kd8h2+MEuUwKUj22UjYQxuqH
4aJR98gEOaXoRnT1kR+ckR+lRoiKAoKCJ.mD6h7sK+P1keJ6JOF6BT4Bda4R
da4hdakxdakBeakBr3JmmCKmt3K4UPBdAaPku.BxuZ6mBCRxuJL3iET5+Ip3
FKcb8xuXsW.a7bYWEEr2eUQsHZu+x7qb23GvW1ie6rUvf6PAibTgP4f3gxkI
oUMLjV0v35KpyGqjIzNhohIgMCT4ThObDWCtNcu.6U7tTYX3UXvIovttXsPM
z6D0wS2NOiz9ge4m+vCwM28InufYnbkTSGysd2cehltvLeRQwKs8bV3ZGO1W
kEDFKk+QcxRfuTlLjXyWBRrG67Fnoj2f6dhpfWJ7lTcTQAIWMkTPcoRpNmH0
TddTRXdMen.ePLWjKdGucrZkPrb4cQx9e6dwXpLgpQnFkovJqKW.RCphKrN4
khVE13ciBzZgSzaKNiDwo35MFgiLHgSbAeuFvbRvlMdNmw1WnDRI0Jz8Zii5
bxOi+I8rneT7pDNKz5R6dsBGPAxh8BmuqMMrInhJD+90C+wA6iVlQdo8QqUs
1sxINw0O2x.90hQPcvCVXhHkkTV4FyEfjaosRxJmJISTjjQpRx6bWEFvZRjB
oP.YN8Nw+3beKq7qp9QGMUT99fMw3M7cNRCd17FK4hMKGBZkKPzz0g1j+bhq
FqbswSKJrhjLYzPwHEoX7nghqoQZ8jLc7PxlppoENdnYiSQCzHglUtSXiwCM
SORA9zflUBm0GOzLQUbdDo2P09SfimNTfp1iBbDoqCNA00Alf3rpcCdgnXse
61xlG9Ltk+t5AoUN+fcRRj6h8IxI.V1d2OIqwsI66diWvBauTavMelpsYxtE
106sE0iSz0F3qOX3Gc8Ww2U5KgmbfjNvCQtlIoKWBoAO3gPZ1MWjqb2YTkZx
kkVGF2ZUTcW0.bFtpANcxRj17nIRt6znjWXbAAmcWErgXRTGaf8M1r1KfUWt
P3.5jjQHhVMX41pYPZ0cd.s1loxJe01pKdRN5y5fnc1BhUeRArDcfx.K1ZxA
rM3XZu4a3loCnc+Vru7LsTQYcwxkSrZEwMaDwYhL1ImnSoc4.v3PGmUdt63v
30.DyDakfnInUPzPAWEcfwOI26JBbXY+JHwRQ1DvQGoReNOGFo8ke4aWCu+s
qQe06XUI5W80rjWSDEJLCGHocYQx3SVj6KdQWHj6b56Iy4mZ2euAcHKd20DA
0Vbg569bj7P5olCVqtDdy8cWse69B5Dt0axILEJRaUboAnPRsFhTa+ogZdy8
glQS4lba0Lpy43yHJwC9vJ6D6Ra1YtuZypIKjd8cgOXW7r52UrmEyBcWlD64
txQXLydtw7O+8FH1OP.62rG1nwGFhEaBnIaRkoOKe87yng7JGr39hEjK2Z.p
6AzSMwZwnRKZhAliHEjjXcPlsauWh6w0.zbC9elbuqyfMMWjdoWD25KhnDKd
UGL2DpaYgK8hjVdQvbnNlMSI9Wj.nHjUQEBaUeEhOWJfAAhJdTBn9GkMRMKS
HwPOcMPJV+lZX6nyjsaHX6PkX6F7MXbX35Djhbc3bJlZQNctdAuFLmWBbjn+
35LkjrggCoJv0oywDnkIQEtN9r35PjvqALtbLczDgoCmqy+y3jY534P.gZPO
4l5.D1Tsl5VVrBVElN4rX5bZWGe4X4jIGKGNm0r0T2pGY4PFeTGXXh6lkyCj
RVlHrRZ2omEK2hwi38Gp.KmyGfH5fvyA5u334HJvzRIdNzzf0otJ7b8wAOGM
r7bzbhLFNvX.F.pooxChiJ5OuVYk1Y4VTBhHhZD5HfU49naQyNUmX.UQytIq
T0sLPpvxMNuAwYxEzw.0X5bn8yu+bfJL8JLOkX5Es+FeLcV6bSKHisqT6bjA
BSMUgoaNYX5vKLS2TDkVF8bcKDvDSTS6tkoAnzH2un6VZRfVRzmzR15nIWMf
3uUKNwNJQ6itIaE4yCTW6BhStSaom6xG44siGQHChXPg15nfchGQiUTh.y0c
Zg16ic82nYuHXeBaRAZwNKC7WEydEs3.M6DMG6kay22BYLxYuLJ+fur6OYcq
6RpG2ZjtoEDYH1qg0cw3ZsUs+LGX+gU16z9kkasWjvPLF94tw021SSTs9LwO
xbVSc9nQNU7SmxWucoqJm59TTRCvmdsv2OFrOxkI77ub9n1GB7V0uHovWX09
BMt6vNq2EunDo+jI1IRbqA1zd2L.ZJjmdo2sq5buNwFIjFLALacQcgWwcSnI
YlGdn+kTvBvQZaDnVkTxCDWuHwA3I.Dl8dSlxcyeacQFNJ.ZoC482a.MDCci
kh8e9zQJEC1lkgKYMqjE5YDj4pG5Y8nljM3tS17sfx.vrT4MxHeO+JHdmD12
jGBbDO+8RuHrAlRml2kBVSQey0vE7JFRCHhUqCAo5VeFbsLlEKEjU9z9lskF
HytLbM7DfqYlBqLdkAeCUJm5D4ZTAKRrtAo+zu7Jh4EjWAu57pFiP7AI8eOD
Hogd.KhaKszEgwjz.BqqVSwkp0zVMIi7Xp2zwp1p3G2prW5sYDA.4lnmNRyV
OOAfMaPPU1u7gusD6y6DEN.C7zRpORFfiIvVQqqmsJGrxYvvBYnQnCn.z2PQ
1pm02ZVvx4kYf5VwxkxZYY0S2cLslkrIFVsKKK3Ux.P4gj1Ch2OCqWCfkFvn
n6MyVsh1delOMd7WvvleLIxq90NwnmsyXI.AP0GtHpK1k7YuLBu.O0KXy9Qt
lm5xyeEokmY85wdwqG6EudrWbQN1KDZDUJjwcRAKGcYbXERT7HU3TBakC6It
PaAs7jsNI1ZuEN7gGKhEpnqWJJa0pOyS5iQPLHq7HHujA0oNBraDboIoR6N5
Y0d7h7ngVpTLzZjEy2j92waWC0dm1aWiX+xscO3WU9gqr0cnqkzud5V4Y7Yd
ffLpCAeBX1IRCnoiLwM1Bgd1XMQIrNcuNL6DpMUN5ZeWMwatwYTUs1v8oZsA
.8ba.iCNYblrGNH81o6TZfZVNirtGJR0S4iwyXMjKx10YvF.gTlQoUbpsAaz
wQ3w39bnYA+rLfO6zqBRikS0ShzRksshzjILRa6ubaPzCe5p.zoZEj.szw6a
EnQSef94qBPCkK9kx.MdBCz+QPvtqj7rzHTLfEmRDshxfo63gEAOh4WKDV5z
qjtOBBaeB2U8f+wqv7URmg9oHLa8pr74AvpJKaLEDk6o0wLcnuptNl5mVzUu
6YWjt05iefJcjqpBTzK558J1x8wOFkMUTEwHxkVXZoCWZ5gOMAfpzgMpJTg6
In54I.TIGXhx6zxkFojC5cJHRoeJ3DrWvomGryuAqoWHMV0Hz834TMP43y83
IFLSmdgfYkO3DPStCNA334bH.gNkSUD33flgSOsbSw3It0D77dv7ReZ.Mhn4
QzA6yj7b0XpddOL0nY7DjlQSPZFN8NZoT+7dPexcdOX7548vYddOzjO0HWNl
gv01sJhFtjVcoa891uFJG9ZtsjkRuyNZiqeYGRQXf0Mj8S1d6kXBxJqh6tyd
iyN63GOvm0NNjJjDDdb4JIi7B1.mUtO5GrfS0Bx+WDj9OIMA9+I6NyCysepF
73G1WKuTYJHZwCCMA7P4QponjZpwfFXT49UoHfvbTsoISTSYepawia7WUe09
C7aUtdyIgZph8iinwWwoAvGWk93hrIC1pslLzIVSlbGE3B2h49hB9R1jonTa
9LZO00b6nICYz1jonN1yNVW7hqhe0k19Q5WcFsF9YtZ9UW7hlcqNbO6VcxPf
kozs5ZEefu5VcM5VcFR+MGhMkptS2YD7qtU2qtU2qtU2kvs55KqYGRKGBDTX
aLwWOqYuurhBoEKAU0d9GutVXesQ2ogsGUAH3jz2KWvCKhGXdhWY2RCIOn.0
UzoLMmxtIgL3TNtfeohgT327Ercix5x1d4ir9H0Zw5Q6MelMEmIR+OqaOBDn
f8id2jvln2L9z4.M0OEcNSYWyZyHTmSZesppyQ+UcNmmNmTbVUcNFuXT4DUi
JmgQzVFDnUUwxT1SDipSwx.o+fbJpOvup93LUePNEsGnIk1i9ZVjjSZRj89b
HutVI83wNMMmdjrplH13xTzgJPwzomonimdlhNd5YJ53WME8OOSjVkVejImQ
cimf14HX5YmiFSOybzZbQxpz7ybxYXlnWMLyyzvLa5DYJNIHr0CkIkCE95RK
HiJmdlzSoaz1WTIlIWu0uHtc0oPHq+GJykhBsOkgVTySxelisrkijuNhanJ0
XnH0fFLpAp.0fGDpgPU.bHUFDw0mdp5NRGqe5RRODUnGqNvmctqBCb8SRaNg
EGxdDKQ6WBQZH0UtBoKO9Fzs3Oo3pBZ3xU4Trgw.w5UrgAbPnFrR5vLOMFeJ
+L8DMgJMd9pWgkluGkJjQDW0Cb9CH7FZ1CFLdOVIczVCG8nhZnCH5qO8P5n0
Q8RiXoKBPkFlwAWI80CpkvWBDW0GRiJoHhNbnMZb0IDFnJ2efvGEHGyAiZPJ
ooFLBomSospob6ELo8RKPDdbIwW0I4UJ7azu7TknG7HidfCF8T0ATaYva5CC
4PUjbnCC4nR+avAaFnPrhjyvLRaHTQxYfDkUQS3YRMxEV4.2dgSHG3tKG3pK
G6lKM6hKG5dKru7ec6+GgLFFB
-----------end_max5_patcher-----------
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    3 Discussions
    coraie
    2 years ago
    Hi!
    To questions: does this work with Max 6 and is there are version implementing a web cam (i sight on mac) ?
    Thanks!
    Coralie
    Yes, it should work on Max 6. Do you run into any problems? As for the webcam, you can find an example of using the webcam in your Max help under [jit.grab].
    Hi, thanks. I think the [jit.record] object is [jit.qt.record] in Max 6 and I don't know if they have the same behaviour.
