3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recording help
Recording help
Have you ever found a sound on the internet that you really want to save to your computer? Did the website let you save the file? If you did find a sound and you want to save it you will probably build this instuctable.
Step 1What you need
what you need
you need the folowing:
tape
two sets of earbuds
about 5 minutes
13 comments
Dec 29, 2010. 2:31 AMrizdek says:
If anyone has software that will create sound files from video clips (e.g. VideoStudio) you can do this.
To get good sound recordings, I had to resort to recording my voice while I video taped. Then I separated the sound from the video clip... easy with VideoStudio. I have also tried recording with audacity, but the sound level is very low. Maybe it's just my mics.
Feb 14, 2009. 3:41 PMlemonie says:
Why not just make a cable that links line-out to the (mono) mic socket? How do you get around Sound Recorder's 60 second default clip-length? L
Feb 17, 2009. 2:31 PMlemonie says:
The mic socket is mono, and maybe needs less volume. But that aside, how do you get around Sound Recorder's 60 second default clip-length? L
Feb 14, 2009. 4:31 PMmikedoth says:
You could use a male-to-male cable and connect the out to microphone ports but then you wouldn't be able to hear the output. The software method I mentioned below you can.
Feb 17, 2009. 2:41 PMmikedoth says:
Then I would suggest going with the software method (Audacity).
http://audacity.sourceforge.net/
Method for doing so...
http://audacity.sourceforge.net/help/faq?s=recording&i=streaming
Dec 4, 2009. 3:12 PMchipbeats82 says:
EXACTLY.  waveout mix is much easier (no hardware) and produces exact replica of original sound.
Oct 14, 2009. 7:59 PMcarlo$ says:
Thanks.  It works, it kicks booty!  Save me from making a cable.
Feb 14, 2009. 4:35 PMlemonie says:
Doesn't this output to the PC speakers anyway?
Years ago, I'd see people placing audio cassette players next to each other, one recording and the other playing, with a preliminary "shhhhsh!"
L
Feb 15, 2009. 11:54 AMchosenone3 says:
there some free software to record things from internet :D Did i mentioned free ? :D
Feb 14, 2009. 3:26 PMmikedoth says:
I tried this once but it's the long way and you loose quality. Install Audacity and have it record from the audio out driver to a file. You can adjust the quality right then and there. This would be good if you wanted to record from something you couldn't find a way to hook up to the pc (i.e. a record player).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TOCO
