For e.g. You should be able to recover all data in case of
1) Windows acting up due to virus infestation
2) Accidentally deleting critical windows installation files there by rendering windows un bootable
3) Accidentally modifiying boot.ini to render windows un bootable.
4) BSOD due to missing boot.ini, improper or wrong driver installtion
This procedure will have varying degree of success in case of
1) Hard disk developing bad sectors and there by rendering windows installtion unbootable
2) There is a mechanical/electronic failure on the hard disk
The things that are required:
1) A computer with a working CD/DVD drive windows you can't boot into
2) A Linux Live CD (I am going to use a Ubuntu Live CD)
3) a Portable harddisk with atleast the free space that will be required for the data being recovered
4) Basic knowledge about BIOS and features
Please note that it is very important to perform this procedure before trying to write anything on the windows installation partition (Reparing windows in OK). If you have already tried to format the re-install, chances of data recovery may be very small. Also any linux installation (Puppy, knoppix, ubuntu, fedora) can be used as long as they support booting from live Cd. alternatively you can also a Live USB. Procedure for making a Live usb can be found at:
1. for ubuntu: https://help.ubuntu.com/community/Installation/FromUSBStick#Installing%20Ubuntu%20directly%20on%20a%20USB%20flash%20drive
2. For knoppix: http://www.knoppix.net/wiki/Bootable_USB_Key
Remove these ads by
Signing UpStep 1Setting First Boot Device as CD/DVD/USB Drive
Assuming that you have all the resources at hand, let us get started.
Please note that the motherboard options for entering into BIOS setup may be different for different manufacturers and Laptops.
1. Start your computer. During POST, note the button that needs to be pressed for BIOS setup utility. In my case, it is the "DELETE" key. Press the delete key to enter BIOS setup
comments
Add Comment
zazenergy
says:
budabob07
says:
Add Comment
