3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recovering You Car's Headliner and Pillars
Recovering You Car\
Is your car's headliner sagging? Is it terribly dirty? Well here the solution for you! The following will show you how to recover your drab old headliner. I will not only be recovering, but changing my color from gray to black.
Materials
I bought 6 yards of fabric - I opted for a "headliner material" which is foam backed
2 Cans of 3M 90 Spray on Adhesive (Do not go cheap on your adhesive)
Cost
Headliner Material: 6 yds. @ $11/yd = $66 | 50% off coupon = $33
Adhesive: 2 @ $13/ea = $26
Considering I'm not using all of the material (only half of the headliner) -- lets say the total cost is no more than $50.
Time
Headliner Removal: 45mins <-- never done it before
Removing old material and preparing: 60min
Recovering: 60min <-- a lot of wait time
Covering Pillars: 20min per set (3 sets)
Covering Sunroof Slide: 20min:
Installation: 30 min
So, this is a good weekend job - remove headliner on Friday (maybe prepare too). Recover on Saturday. Install on Sunday :)
Warning
Some vehicles are equipped with curtain airbags located in the headliner itself. I don't know how the airbag deploys nor do I know if the headliner material will effect operation. Likewise for pillar mounted airbags. That is one system you don't want to screw around with. <-- Just like seat mounted airbags -- you're not putting seat covers over them right? :P
Step 1Remove Headliner
Remove Headliner
This will vary from vehicle to vehicle... For my car (Mark IV Volkswagen Jetta/Golf) instructions can be found here: http://forums.vwvortex.com/zerothread?id=1312975
16 comments
Jan 2, 2012. 5:27 PMScanner2 says:
Kudos on a nice instructible! I did this once on a 78 Chrysler. First, I tried the needle and thread idea- it holds the liner up, but only where the thread actually is. So if you have lots of patience for threading (and your headliner is perforated already) and you don't mind a loose headliner when done, that will work. However the good Adhesive seems to give the best result. The foam backing on the material seems to be there for noise absorption.
Jun 13, 2011. 5:28 AMCrackersouth says:
Just curious as to how old you VW is. Seems to be a lot of damage for supossably a well made vehicle. I'm in the process of using Dupli-color vinyl and fabric spray on my headliner for my 1962 Corvair. My headliner uses ribs and staples so it will be done in place. I will have to do a lot of masking and trim removal.
Nov 3, 2010. 9:51 PMelephantsoup says:
I am a professional auto upholstery tech. Nicely done. Hot civic ^^^ is correct about the glue, this is what I use. It can be applied with a 30$ paint gun. It is essentially sprayable contact cement, decking adhesive also works well provided you make sure you buy the sprayable variety. The other will leave a huge mess trust me.
As far as removing the old foam a scotchbrite pad works well. I will caution people that there are several types of hard headliner depending on vehicle make. Some are cardboard, others are pressed fiberglass. The fiberglass ones are easy to wreck. Use caution not to disrupt the outermost layer, it is semi-sealed and once you go past it will deteriorate easily and make u itch like crazy.
As far as alternate coverings go, I would say vinyl is too heavy for a spray can glue, but I have used vinyl and leather with professional glues no problem. A nice light alternative which is popular these days is faux suede.
Mar 6, 2010. 11:07 PMhot_civic03 says:
I would recommend to any one recovering their headliner to us "DAP weldwood landau top high heat resistant contact cement"   Yes the name is huge and so is the stick  especialy for vinyl my headliner is recovered in vinyl and it took two tries before i found this product and it has been great for 2 years now and i live in the desert where temps reach 120 in the summer.  the only problem with this product is it doesn't come off  so be carful and get your fabric on smooth the first time or you are in for a lot of work.   Good luck
Feb 11, 2010. 11:39 AMsprocketscientist says:
 Nice instructable. Kudos that its also the only headliner instructable I could find.
I'm going to have to do this to my '95 Ford Escort. Hopefully I can figure out how to remove the headliner.
Aug 3, 2009. 7:40 PMnitsuaustin says:
Do you think I could replace my headliner with vinyl?
Nov 26, 2009. 10:03 AMjmar10 says:
That is a great question to ask. I would really like to know if using a foam backed headliner is absolutely necessary or not. I am about to change my headliner out soon and prefer not to use the same foam backed material because it actually will deteriorate and cause problems again. I know that the deterioration of this foam is toxic.
If anyone has an opinion on this, please post it.
Thanks
Aug 28, 2009. 10:03 AMVampireXTC says:
Did you strip the pillars before applying the vinyl? I've got everything out of mine and the headliner cloth was easy enough to remove but the pillars are pretty well glued. Just wondering if there were any suggestions. I'm thinking heat gun but would prefer something a little less drastic.
Mar 21, 2009. 1:53 PMjennifer05 says:
Thanks so much for the info I have been wanting to replace my vw golf headliner so bad. but i had one question how do i get the clips off near the viziors and the center panels that hold up the head liner?
Apr 24, 2008. 6:46 PMehmbee says:
Good instructable! I did this to my grandmother's Buick, as all 80s GM cars, it seems, suffer from sagging headliner fabric eventually-we managed to find some curtain panels at Big Lots for ten bucks that were the perfect size. Since it was her car, and an old one at that, we did not care too much about a match, so we used the curtain, which had a raised floral pattern. if you wanna get nuts, try some fabric you find for cheep. In the end it had a Victorian Steampunk look in a way.
Sep 5, 2007. 9:48 AMjettagli says:
Hi me and my friend were just about to do this and was wondering you u bought your material? i have a Jetta and my friend got a GTI we have gray pillars and headiner i want mine to look like the black headliner on the 2004.5 gli so what material do i need and where can i find it. Please respond by sending me an email at Miamivdubs@yahoo.com Thanks
Apr 30, 2007. 6:56 PMcarpespasm says:
an easy quick fix i've seen used is to push put a pattern of those needles with the colored tips used to hold together clothing patterns.
Jan 28, 2007. 8:40 AMmatchbookhymnal says:
This is a good total re-do. Definitely remove all the foam or your headliner will just come right back down again. If you need a quick fix to keep a headliner out of the way until you can re-glue, try using a thin, flexible strip of wood wedged between the plastic pieces above the doors. My grandpa used a piece of old molding for years this way.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
