Re-create Heron's fountain from water bottles
Re-create Heron\
I originally made this project for the MAKE blog. It's a fun experiment that led to a lot of discussions about perpetual motion and free energy. My version does not exhibit either of these properties, but you may be able to fool people into thinking it does.
This is a really easy build and would be a perfect project for to build with your kids. Maybe you could even sneak in a lesson on fluid dynamics or perpetual motion?
Step 1What You need: Supplies
Here is a lit of the items you need for the build. As you can see, it's not a lot. The total cost of build = $2 (you can scavenge the 3 water bottles)
(3) 16.9 FL OZ Water bottles
(1) 9" length of tubing
(1) 11" length of tubing
(1) 15" length of tubing
Small amount of clay
Note: The tubing is for aquariums and is 3/16" thin wall rigid tubing. Almost any tubing would work, even flexible, but the rigid makes it really easy. I was able to pick some up at a local pet supply store for about $0.50 per foot.
46 comments
1-40 of 46next »
May 30, 2011. 11:15 PMHamenChips says:
How long will it last?
Jan 13, 2009. 9:04 PMlittlechef37 says:
THIS IS AWESOME... 5 STARS
Jan 15, 2009. 6:10 PMlittlechef37 says:
I wonder if would an EXTREMELY large version of this (with a generator) would produce enough energy to add and remove water to keep it running forever.. and possibly generate enough power to run a house or charge an iPod or something ?
Nov 1, 2010. 9:36 AMrocketkid says:
if you used the water to run a generator, then yes you would get electrical energy. the problem is, you arnt going to make more energy than is used up adding the water back into the system. the system can be as complex as you need, but with our laws of physics, it is impossible to produce more energy than used. this includes using temperature change, gravity and all forces that arnt part of the actual system as well.
May 18, 2010. 10:09 PMA good name says:
Perpetual motion doesn't exist. There are many devices that utilize energy with amazing efficiency (perpetual motion clocks can power themselves for two days with a change in temperature of only 1 degree)
But perpetual motion defies the laws of physics.
However, I thought this was pretty neat.
Jun 27, 2010. 8:52 PMshdggsdv says:
actually just because it defies our laws of physics doesnt mean its not possible, that sounds impossible to most but try to explain black holes while staying in the lymits of our laws of physics, i would explain some of this more scientificly but iv been stripping paint on 2 guitars all day as well as repainting several and to put it simply the fumes got to my head
Jun 27, 2010. 9:50 PMA good name says:
No, perpetual motion is physically impossible.
Aug 3, 2010. 7:11 PMkoskostick says:
really, huh? then what is powering all these spinning atoms that make the entirety of the thing we call physical reality? is it mass delusion? everything that exist is perpetually moving.. we are being hurled through space and even that space is being hurled through larger space and everything is constantly spinning..large and small. all of it. moving - perpetually.. someones gotta to say it.
Aug 3, 2010. 10:26 PMA good name says:
That isn't what perpetual motion means.
Mar 8, 2010. 12:36 PMMillenniumMan says:
Add a small turbine that can turn whatever water flow there is into electrical flow. This electrical flow can run a small compressor which will add pressure and keep it going forever :)
Mar 8, 2010. 12:44 PMMillenniumMan says:
Can't believe I didn't realize this until after I posted.
We didn't consider the waters' evaporation from the unit. Eliminate that and it'll last muuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuch longer.
Maybe seal the top or something?
Nov 24, 2009. 11:47 AMGonazar says:
After the water goes into the bottom container, and the air in the second, how does it reset, or is that the point where it stops?
Jan 25, 2009. 10:38 AMjhonny says:
I wonder if u could make one that runs forever? (>_<)
Oct 4, 2009. 9:42 AMjuanvi says:
water stops running because its viscosiy, if you managed to do that same fountain with liquid air, as it has 0 viscosity, you could make it running forever
May 23, 2009. 3:30 PMSoapyHollow says:
Wow, neat!
Apr 22, 2009. 2:34 PMSenileFelineS says:
Hey that is so cool! What if there was a way to drain the lower container without disrupting the system, and use rain water to refill container b (the middle one). Then it could run forever, as long as it rains. I forget the name, but it's this cool little trick cup that when you start drinking out of it, it drains out the bottom onto the lap of the victim. It usually has a structure extending out of the middle of the bottom of the cup (on the inside). Once the top of the structure is exposed to air (after some drinking) little holes at its base let the fluid flow out. I wish I could remember the name of it so I could find out how it works. So basically, something like it would drain at a certain point when the water got to high.
Jan 31, 2009. 10:29 AMJaycub says:
You should make a giant one that is powered by rain.
Jan 13, 2009. 7:27 PMArbitror says:
I'm doing this right away! (rated 5 stars***** and favorited!)
Jan 12, 2009. 8:05 PMangelofdeth68 says:
good job! it is quite interesting, considering how simplistic it is. 5*
Jan 12, 2009. 7:36 PMFaqMan says:
It is interesting, green, and classy good job.
Jan 11, 2009. 10:52 AMA good name says:
Oh and I subscribed, hope to see more of this stuff from you!
Jan 11, 2009. 10:53 AMA good name says:
:) Just a note Html doesn't work on here.
I agree, you got this thing made! Genius idea! Lol I feel like I finally understand physics.
Jan 11, 2009. 10:01 AMnepheron says:
Enjoy your new voltiac backpack! You have this contest by the NECK...
Jan 9, 2009. 6:39 PMguyfrom7up says:
Lol, I was actually considering copying your article from make and just making it into an instructable, but you did this which is good also ;) 5 stars!
Jan 9, 2009. 8:39 AMRob K says:
How about using 2 litter or 3 litter bottles? How long do you think it will last?
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:wurx
I make things.
