3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recumbent Bicycle from Garage Refuse
Combine an old BMX bicycle, wood, EMT conduit, and boat seat, to bicycle in laid-back comfort. Save $100's off the cost of a new recumbent bike.
Step 1Use wood for a main beam across the top of the BMX bike frame. Wood is easy to work with, but does flex a little when you peddle.
14 comments
Mar 21, 2012. 4:44 PMAron313 says:
Hit a jump!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 2, 2010. 10:24 PMThe nerdling says:
WOW, WOW, LOL, COOL, EPIC, WOW AGAIN, COOLOPIC, ETC, ETC
(|O|}) BURGER
Jul 14, 2009. 3:50 PMmacrumpton says:
is the middle of the boat seat where the seatpost used to be?
Jan 28, 2009. 11:40 AMCapt. Fat says:
This is the funniest bie I ever seen!!!LOL!!! 5 Stars!!!
Aug 2, 2008. 2:53 PMsennomo says:
Great idea. One very minor suggestion: Shouldn't the tense side of the chain have the bigger guide wheel?
May 27, 2008. 11:39 AMnowuknowjack says:
I like your design. Quick and simple. Check out Recumbent Cyclist news for other ideas. Look for their home built issue that was available on line (don't know if it still is). I built a similar project BUT used various parts from junk bikes to make it rear wheel drive. Where the BMX crank was, I used a chain ring with three sprockets and removed the crank arms. I used various bike tubing to create a boom out front reinforced with angle iron from an old bed frame and muffler clamps. The main crank assembly was up front and after some trials I got the length and angle of the boom just right for me. I routed the chain through 1/2 inch drip irrigation tube to the BMX crank then back to the rear wheel whic was replaced with a 20" 7 speed wheel. I used lots of muffler clamps, J.B. weld and NO WELDING! I would post it on instructables but this was several years ago and it has become parts for other projects.
May 7, 2008. 11:03 AMmanmelvin says:
How do you turn and pedal at the same time?
Feb 10, 2008. 8:34 PMgarrettmikesmith says:
that is awesome. i wish i still had that boat seat in my garage.
Jun 11, 2006. 12:18 AMtrebuchet03 says:
Very nice - how do you like the FWD? I'm a fan of 'bents :P And considering they are quite expensive new... homebuilts are always a treat... expect a 95% wooden 'bent prototype from me soon :D
Oct 15, 2006. 11:55 PMWoodenbikes says:
Cool Bent! I built an experimental scooter with front and rear steering but it spins out and dumps me. I don't recommend rear steering as it leads to positive feedback once the turn starts. The centrifical force of the turn throws the back end out and the turn spirals in sharper. You may get a kick out of my home-builts at www.woodenbikes.com
Dec 23, 2007. 9:23 PMkillerjackalope says:
give yourself no more than 5 degrees of steer and that way you can drive the wheel easily and it gives some serious tricks and a$$ savers as options, you hit a curb (the ramp ones) at high speed firing the front wheel up and there's people up ahead, you turn the front wheel before it hits the ground and you're a$$ over tin cup but a quick shift of the hips will move you sideway in a really odd way (diagonally kinda) and in mormal cornering it makes it easy to swing round and ride in a slight diagonal. when you sit normally you get no odd effects
Jun 11, 2006. 8:00 AMradiorental says:
how do you turn the front wheel without poping the chain of the derailleur? very cool project, seat looks comfy
Jun 11, 2006. 8:01 AMradiorental says:
sorry, just read step 3 - cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:dome_head
EE, semi retired
