Recycle Dry Cleaner's Pant Hangers Into Camisole Hangers
Introduction: Recycle Dry Cleaner's Pant Hangers Into Camisole Hangers
The cardboard tubes on dry cleaner's not only don't last very long but have a sticky coating which keeps your pants from slipping off the hanger but after a few uses becomes covered with lint, hair, etc. (basically gross!)
Removing the cardboard tube leaves you with a not very useful partial hanger.
Here is a quick and easy way to convert this into a hanger for lightweight items such as camisoles.  My camisoles need hangers with notches for straps and those are harder to find and more expensive than just plain plastic hangers.
Step 1: Gather
Gather together all your old dry cleaner's pant hangers.
Tools Needed:
Wire Cutter
Pliers with built-in wire cutters
Step 2: Cut
Remove the cardboard tube.
Use wire cutters to cut off the bent ends of the hanger.
Step 3: Coil Ends
Use the pliers to coil the ends so the cut end is inside the coil.
My ends were not rough and they coiled neatly inward but if you think the rough ends could snag your clothing then maybe a little dot of "shoe goo" on each end before coiling.  But that will add at least 24 hours to the project to let the goo dry completely.
Step 4: Hang Camisoles
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    So simple, so clever, so useful! Thanks for sharing!
