Remove these ads by
Signing UpStep 1: Find the right sized book
On second thought, why not breath new life into that old Masters thesis as a personalized iPad case? You're probably not going to read it again are you?
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Now that I am a user here also, I hope to be able to share some projects here too. ;)
Am in New Zealand so would be happy to pay ya for the postage. Hey, did you just have another Earthquake? A 5.5?
I'm not on Twitter. Are you on Facebook?
Send me a private message on Instructables with your address and I'll send the photos.
XD haha
Actually... fitting one's tablet and smartphone into the same book might not be such a silly idea. Hidden in a boring book in the bookshelf, no thief would ever find them. I'll have to try it whenever I get both/either device (currently have laptop and iPAQ HW6965).
Me : "Reading."
a few couple comments,
I used a glue stick to glue pages together individually just 3 sides say 1" wide along perimeter.
this made the pages a littl rippley but not bad . make sure you smooth them out . close book often so pages are lined up .
i cut with exacto knife then the drum sander which worked great .
2 problems
I made a small half circle cut out in the center by the binding with the drum sander to aid in removing the i pad .
this worked great but this area was not glued so when sanding it bulged this area making it thicker . should have possibly cut out with knife first or glued along binding .
also i ran out of glue sticks using white liquid (elmerrs ) seemed more ripply in that part .
Next project the magnet .
I like the idea of the half circle to get the iPad out. I might add that to mine.
You can get rid of the bulging with (small) taps from a (small) hammer, then clean up any uneven-ness with the sander.
Did the glue would make the whole thing thicker? I originally thought about doing some glueing, but mine worked without (probably because of the thicker photo paper).
Thanks for the comment.. Magnet progress photos?
If you write a new Instructable, I'm happy to put a link from here to it.
1. I don't know if the rounded corners to the opening are especially necessary-- but I guess they don't add too much difficulty.
2. To keep the pages stacked properly during cutting, perhaps a person could use some combination of ratchet claps and some metal with a straight edge.
3. A sharp blade will make short work of the cutting. The depth of the cut could be restricted either by inserting some barrier below the bottom page of the cut.
4. I suppose if a person wanted to keep their iPad plugged in while in the book, that would require some additional engineering to accommodate the plug-- (perhaps that was addressed already).
It will be awesome !!
Thnx a lot for this idea
Cheers!
You could also then drill and insert small yet powerful magnets in the "edge" to keep the cover closed.....
For added security you could also use elastic diagonally on the corners and secured to the inside of the back cover to hold the ipad inside the pages.
And the paper clip for the power button was a nice touch.
secondly, (WARNING: CRITICISM AHEAD!) wouldnt it be easier to attach a premade ipad1 case to an old book spine and cover, then add false pages to the edges?
Just remember, only the top sheet is visible so making it perfect underneath would only look good when you're not using it
Thanks.
So... I might just have to do it for fun. I'd include two magnets on the front cover (one to lock the cover down and one for hibernate) as well as glue the pages together and the extra hole on the side/bottom for the charging cable.
Two thumbs up!!!!!
Something like this: amzn.to/lHn3x2
Try it!
You should cut a whole to put the charger through, and then bind it.
I've been meaning to do something like this for my ereader as well. I really like how yours turned out :D
Two thumbs up mate and thank you for sharing :D
