Step 4Start removing the Components
Sometime , you will get to bigger components with bigger lead, to help, you can help you by using a desoldering tool like the one on the picture, its very not expensive, and can help you a lot getting bigger components out. To use it, heat up the lead, then when the solder is melting, put the pump close and hit the button to suck up the solder. Then when you will cock the mechanism back, the sucked solder will come out. Be careful because solder pump have a plastic tip so try to avoid contact with your soldering iron
comments
Add Comment
Add Comment
