Recycled Bobbin Winder
5,376
86
5
Posted in CraftSewing
Introduction: Recycled Bobbin Winder
About: I like to make.
My Grandma wanted a dedicated bobbin winder. She liked the way one of her sewing machines wound them so I copied the setup it had. I made it with scraps I had lying around. Works pretty good.
Step 1: Materials
  • little DC motor
  • Dowel that fits the bobbin
  • Wood
  • Epoxy
  • Washers
  • Nuts
  • Bolt
  • Basic tools
Step 2: Find a Motor
I had an old nail sander that I took the motor out of.
I took the switch out as well.
Step 3: Cut Dowel for Bobbin
Cut a short piece of dowel and sand the end round.
Drill a hole in the flat end slightly smaller in diameter as the motor shaft.
Press the dowel on the motor shaft.
Step 4: Make a Thread Tension
I found some washer and domed them with a ball peen hammer.
Put the to washers on first domed sides together then the two nuts tightening the two nuts together.
Ended up not using the square one.
Step 5: Layout
Layout where about you would like everything placed and mark the locations.
Step 6: Motor Housing and Thread Post
Drilled a hole in a piece of wood the size of the motor part way through. Then drilled a smaller hole for the arbor.
Drill a hole in the bottom for the thread post and glue in.
Step 7: Glue Up
Center the motor in the housing and glue i with epoxy.
Then glue the motor housing to the back board.
I cut a small piece of wood and glued it to the back to bring out the thread tensioner.
Drilled a hole smaller then the threads of the bolt for the tension and screwed it in.
Step 8: Electrical
I took the C battery box off and soldered a AA one I had in the junk drawer.
Screw the switch and battery pack to the back.
Thought AA would be more convenient.
Step 9: Testing
Got an empty bobbin and thread turned it on and it works like a charm.
There you have it a Dedicated Recycled Bobbin Winder.
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    5 Comments
    Good work.
    Does not the thread tensioner need a soft spring?
    I thought the same.
    For a even tension on the bobbin you need a spring, if you look at your sewing machine you will see that the domes are flexible. If the thread got a knot or thickness (especially by low cost thread is this a problem ) then it wil not break.
    @LoMac what do you think about a end switch?
    I was in a bit of a hurry and I was just working from a picture so I didn't notice a spring. I could probably salvage one from a clicky pen.
    I thought about putting a switch to stop it wouldn't be hard at all but she said it's fine without it.
    Very nice ! I was working on a similar project a few weeks ago. Your design is neat and will inspire the mark II of my winder.
    This is great, thanks for posting it.
    Warmly
    Scott
