Recycled Bottle Lamp
561
12
Published
Introduction: Recycled Bottle Lamp
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
In this instructable, I will share how to recycle an old VAT69 bottle into a tabletop lamp.
This is small build can be completed within few hours
If you like the article please vote for me
Step 1: What Do We Need ?
Material
- 3/4" plywood
- 4/32" plywood
- Empty Vat69 bottle
- Pva glue or fevicol
- Led copper string light 4m
- Old usb charger and cable
- Acrylic paint
- Wood polish
Tools
- Jigsaw power tool
- Square
- Sand papers
- 3" clamps
If you don't drink, get it from your best friend who does. I used this bottle due to it's unique shape..
Step 2: Base
- Cut 3 squares of 3.25"x3.25" of 3/8" plywood
- Using pva glue, sandwich all three together and hold tight using clamps
- Make sure to align as many sides as possible, this will save sanding time
- Let it dry for 2hrs
- Drill a hole at the center with a 35 mm or 1.37" bit
- Add a 4/32" plywood as base
- Let everything dry for 2 hours
- Drill a 6 mm hole from the bottom side of the base towards the centeral hole. We will use this hole for usb cable
Step 3: Base - Finishing
- Sand all sides of the base using a 60grit sand paper
- Once everything is in line, use 80 and then 180 grit sand papers
- Collect the sawdust and mix with pva glue to make a clay like consistency
- Fill in all the gaps or cracks using this sawdust clay
- Let it dry for 1 hr
- Sand it, with 180 followed by 220 grit paper
- Use dark brown acrylic paint to stain the wood
- Let it dry for 30 minutes
- Apply 2 to 3 coats of wood polish
Step 4: Add LED Lights
- Pass the usb cable from the bottom of the base towards the central hole
- Solder positive and negative rails to the usb cable
- Insulate the wires using a heat shrunk tube
Step 5: Attaching Bottle
- Add a foam sheet to fit the bottle tight i the central hole
- Push the led string inside the bottle
- Keep the lights on, so that you see the pattern that is being formed inside and should adjust to one's liking
- Fix the bottle and we are done
Place it on a side table or center table and enjoy the bottle lamp
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • Water Contest
      Water Contest
