3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recycled Copper Butterfly for V-Day
Step 9The base
The base
Now I used a candlestick for my base. It was a 1 inch taper candlestick. The reason I chose the candlestick is obvious, it's awesome, but never used. Made of silver and brass it was perfect.
To mount the support bar I simply unscrewed the top of the candlestick, revealing a hollow middle.
I then cannibalized an old trophy of mine to get that long screw. The screw didn't even need to be cut off! You may have seen the support bar had a hole at the base, perfect for mounting.
Insert trophy screw from bottom of candlestick, strategically placing a nut on the bottom to keep it from comign through the center. I then bolted the support pole to the candlestick, only to encounter a problem. It looked rather unsightly with that big metal bolt and nut right in the middle.
So I delved through some stuff and located one of those handheld butcherknife sharpeners. On the bottom end it had a removable steel cap, that was originally used to hang it. It fit the bolt perfectly and was placed on the top to ease the looks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Legionnary
