Fire Starter Pods From Lint and TP Rolls
Published
Introduction: Fire Starter Pods From Lint and TP Rolls
This is an Instructable to make totally recycled Fire starting Pods for Camping , BBQ, or Fireplace.
Elmer's Glue is the only thing that needs to be purchased at $1 a bottle at the dollar store.
I was trying to come up with ways to use the lint from my dryer, so I did a search. I certainly don't plan on making any Doll's so Lint for Stuffing was out. I did notice use for starting fires lint was recommended, although all used said to make pellets with wax. I figured I would have wax in my BBQ or wherever.
So I figure we all end up with empty TP roles, that we throw away unless I get a WORM COMPOST.
So why not utilize getting rid of both.
I am making this to to get rid of Laundry Lint and TP Roles while making something that has purpose.
Step 1: TP ROLLS
First take the toilet paper role and cut 4 slits in each side spaced out.
Repeat the process on the other side
Step 2: Make Holes
Use of a hole punch would probably be best but I used a Wood Spade Bit . You just want air holes though out it to circulate air.
I did staggered, but as long as air is through it , It's all good.
Step 3: Glue Tabs Down on One Side
Push each tab down and use the Elmers to adhere it to the other much like doing coin roles. If you remember that!
If you are doing multiples you could make a jig just to put them all in a hole and put weight on them.
Step 4: Add the Filling
Laundry lint is one thing that is a total waste.
Lot only is it left overs from your cloths it's freaking CLEAN!
So I suggest using it for Fire. If you want to make Doll's thats fine too. If you can save up for years, Insulation for the house ( Fire Hazard though ) . I choose Fire!
Step 5: Fill Tube
Fill Tube with Lint.
Step 6: Seal the Tube
REPEAT STEP 3
Step 7: All Done
You now have a little fire starter and got rid off your TP Tubes and Laundry Lint in one shot. If you Camp, Have a fireplace, firepit, BBQ this might be for you if not.
You can always make (stuff) dolls it's free material!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Outdoor Fitness Challenge
