Step 4Finishing it all up
RED BLACK BLACK YELLOW
+5v gnd gnd +12v
Plug the Molex Connector into your HDD, turn on your power supply and watch it spin up.
If you are using an alternative power source, remember that you will need to give exactly 5v and 12v to the Molex.Otherwise, the HDD's controller will not start due to power deficiency.
You will also need to supply about a total of 2 watts to the 5v and 12v lines.The wattage depends on the RPM of the HDD motor.Generally, this rating is printed on the large sticker covering the metal RF shield.
That is why this project is much easier with a benchtop variable voltage PSU.
The PSU can provide the HDD the current it needs by monitoring the current draw of the HDD.
Picture 1 courtesy of 'www.pcguide.com'
The advantage of this approach is that, with proper addressing of the sand grains, you can actually sand patterns into the piece. You should be able to write a program that can even "monogram" the wood with a little effort (warning, writing the program in lisp will mean every "S" will be replaced with "TH", just so you know).
Kabir
