Step 5Tests: Grinding
TEST 1 : GRINDING WOOD
The sander performs very well and smoothens down the wood quickly.See video for the demonstration.
TEST 2 : GRINDING STEEL
The sander effortlessly grinds through the steel, although better performance would be reached with specific, black steel grinding sandpaper found here: http://www.hartvilletool.com/shared/images/products//large/29887.jpg
I got a little more power/torque by removing the extra platters.
Also, if instead of pushing the sand paper into the small disc securing the platter you decide unscrew the screws, remove the small disc, use it as a template for holes in the sandpaper, and mount the sand paper by securing it with the screw that secure the smal disc and platter in place... than the whole assembly will not vibrate and will not be off center (be careful to cut the sandpaper as raound as possible) and this is good for speed, torque, power.
Post pics of the sander if possible.
That won't actually do anything though.
1. Because HDDs use high-speed/low-torque motors, it may not have enough torque to move the flywheel.
2. It would dramatically increase the complexity of the project, to the point where that much effort would be silly instead of sourcing a motor designed for this type of high-torque/high-speed application.
If a suitable object were found, not fabricated, it would still remain a simple project.
Yes you can buy a motor that is better suited for this project but the idea here is that you are.
1. Using something that would have been thrown away and therefore extending it's lifecycle. A large number of instructibles are about recycling.
2. Providing yourself with a tool that some people cannot afford.
If you want to easily add some load, just take a bunch of hard drive platters and put them in one drive, after removing the spacers that are usually between the platters.
The problem you'll likely have is that a lot of hard drives controllers are built assuming a specific load for acceleration.
once they're up to speed, they may check phase currents to know when to switch, but usually during spinup they just ramp up the switching at a rate they know the motor can achieve. When you throw some extra weight on it, you might lose steps, and have the motor go out of sync.
Sometimes they'll just get confused and burn up, etc.
It really just depends on the drive.
I agree, as to the purpose. I think that this could also be useful for doing extremely fine grit sanding where you'll have very light motor loads, and sanding discs for a commercial sander might not be easy to find.
Sharpening exacto knives, etc..
I'm bypassing the controller entirely and putting power to the motor itself. For this a controller isn't needed.
you might get up to around double before you start having heat problems, and that's probably optimistic. Many motors won't make it that far.
You're still orders of magnitude below a real sander. The main benifits are high speed, and an extremely flat smooth surface. a few drives with some really fine grit paper stuck to them, and you could have a very nice tool for sharpening tools (wood plane irons, chisels, xacto knives, etc)
I've seen some very fine grit papers with adhesive backing. That would be ideal.
the only way to drive these up to speed is with a 3 phase switching controller.
The most practical way to make it run significantly faster is to run it with a separate controller at a higher voltage, You can get controllers intended for RC vehicles which will work on this type of motor.
The controllers aren't actually that expensive but even It's probably still not enough to make it capable of anything needing any significant torque.
I would just use this to sand very small things with fine grit abrasives. Find a real sander for real sanding. I'm all for recycling your junk, and I think this could be a great tool, but it's not a replacement for a full size sander.
Most motors can take more voltage than they're rated for. Doubling the voltage may shorten it's lifespan significantly though.
More voltage will push more current, which means more torque, and more power.
The two are interrelated, after all.
It obviously lacks torque...but still useful. Good job.
btw
Emery is mostly aluminum oxide, with a sprinkling of other minerals...
It will get a red and raw sheen.Be careful.
Like this: http://www.3m.com/product/information/auto-pak-emery-cloth.html
