Recycled LED Tube Light
1,680
14
8
Posted
Introduction: Recycled LED Tube Light
it's easy to make at home
Step 1: How to Make a Led Tube Light
Now you are going to see how to make a led tube light by recycling the electronic waste material at home and it is energy efficient to.
so i will show you how to make it step by step.
Step 2: Material Required
  • fluorescent tube bulb
  • tester
  • screw driver
  • cuttingplyer
  • wire cutter
  • soldering kit
  • old mobile cahger
  • wires
  • tape ang glue
  • LED's
Step 3: Removing of the Cap
remove the capes of the tube light on both sides carefully.
Step 4: Making Hole
make hole carefully by using tester and screwdriver and be care that the mouth of the tube may break.
make the hole till the led's pass through the hole and clean it well by removing the insided matereal of the tube light.
Step 5: Plaseing and Fieaxinging the Led's
put the led's into the tube light through the holes and fix it by using glue an let it dry.
Step 6: Fixing the Capes and Testing
now solder the led's wires to the capes and tape it well to the tube on both sides.
now take the battery an please the battery at the fines of the cap to now the +ve side and -ve side of the led's and to see that led's are working.
Step 7: Wering
take the two wires of different colors and a few inches long then the tube and wind the one wire to +ve side and -ve side to other wire and it well to fix it.
Step 8: Power Suppely
to get the power remove the motherboard from the charger and solder the wires +ve to the +ve side and -ve to the -ve side on it and plase a small papper base at the base of it abd glue to it
Step 9: Fixing the Power Suppely
tape the power supply to the tube well and the led tube light is finished place the tube light any ware in the house.
Step 10: When Power Is Supplied Led's Glow and to Get More Bright Place a Other Layer of Led's in It
Step 11: THANK YOU AND SHARE IT. HAVE a GOOD DAY.
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
8 Comments
nice one...how to remove the tube cap...any tips and tricks...
just twist the ends of the tube cap little hard the case will be loose, then cut the wire or desolder the wires from the tube cap
Breaking the fluorescent light is hazardous as they contain mercury and phosphor ........dont do it.....
yes my friend fluorescent light has mercury and phosphors but now a days phosphors is not used and mercury-vaporgasand the amount of mercury in a fluorescent lamp varies from 3 to 46 mg, depending on lamp size. Newer lamps contain less mercury of 3–4 mg and up to 2006 12mg is used. so stop mercury sulfur is used to form mercury sulfide.
A quantity of 25 kg of dust sulfur is enough for 1000 tubes and the easiest way to combine sulfur and mercury is to cover a group of fluorescent tubes with sulfur dust and break them.
Great job on your first Instructable. I like that you are reusing the fluorescent tube. I hope we see more from you in the future!
