Introduction: Recycled Lightbulb Vase
This is an instructable to recycle and reuse old lightbulbs. Once a lightbulb goes gets fused they normally go waste and have to be thrown away. I've re-purposed them converted them into vases for my money plant! They look beautiful and are super easy to make.
Step 1: Materials
1 old light bulb
pliers
screwdriver
sandpaper
moneyplant
Safety goggles and gloves
Step 2: Safety and Preparations
Step 3: Removing the Knobs at the Base
Using the pliers pull out the knobs at the base of the bulb. It may take a little bit of force but they do come out.
The bulb i've used has a 'bayonet' type of base. for bulbs with a screw type of base this step is not required.
Step 4: Pulling Out the Soldering
Now using the pliers again pull out the silver soldering at the bottom of the base of the bulb. they would also require a little force but they do come out easily.
Step 5: Clearing the Base
Now using your screwdriver start chipping and breaking the black glass base of the bulb.
Be gentle while doing this, the black glass here is thick, but easily breaks off.
Step 6: Hollowing the Bulb
Using the screwdriver slowly start break the inside part of the bulb where the filament is located. Hold the bulb with a tight grip, but not too tight or else the glass itself will break. Be patient while doing this.
Once the inside is broken it should easily slide out!
Step 7: You're Done!
Voila! the bulb is empty! Wash the bulb once to remove all broken glass pieces. Rub the sandpaper around the base of the bulb to smoothen out all sharp edges and prevent any cuts.
Now pass a thick thread through the holes so that we can hang the bulb!
I've put a money plant in the bulb and put water in it. It now hangs nicely in my room!
If you like this instructable please do vote for it in the 'Trash to Treasure' contest being held!
Thank you.
