Recycled Map Bangle
11,493
262
15
Published
Introduction: Recycled Map Bangle
You will need:
Map
Glue Stick (does not need to be fancy)
Bangle Form (Use a bangle you already have to find something the same size. Mine is a coffee mug)
Decoupage medium (or liquid glue mixed with a bit of water)
Rotary Cutter (you can use scissors too, if you want)
Ruler
Board (to protect surface from blades
Memory wire
Scotch tape
*I got the idea for this from this instructable. I added a bit to make it more suitable for a larger size.
Step 1: Cutting the Paper
Using the rotary cutter, cut strips 3/4" wide. I ended up using thirteen 24" strips.
Step 2: Wrapping
Lay one of the strips down. This will be the inside of the bangle, so have a pretty/interesting side down.
Put a liberal amount of glue on the surface of the paper, making sure to get the edges.
Tape the end of the strip on the form, making sure the glue side is facing out.
Wrap the strips around the form, making sure the edges line up. When adding new strips, overlap the ends by a half inch or so.
Wrap a little less than half of your strips.
Step 3: Adding the Memory Wire
Halfway through wrapping, add memory wire. This gives the bangle more strength, making it less likely to get squished (as paper often is).
Cut a piece of memory wire that can wrap around the form and over overlaps about 3/4".
Put a piece of tape sticky side out on the wrapped strips. It should be higher than center.
Place the memory wire around the bangle, centering the overlapped ends over the tape. Make sure the wire is in the center of the strips the whole way around.
Fold the tape over the ends of the wire and press it together.
For the rest of the bangle, wrap strips glue side in. On the next strip, have extra glue and make sure you really press the edges down around the wire.
Let dry for a few hours.
Step 4: Finishing
Remove the bangle from the form and try it on. If it's too large, you can add more strips to the inside. This is a little trickier than wrapping them around, but it's not terrible.
Coat the bangle liberally in decoupage medium, being sure to coat the rough edges on the side. Let it dry on a rack, and move it every so often to keep it from sticking.
Add another coat or two until it seems very firm.
Step 5: Wear It!
Wear your beautiful bangle, and proudly tell everyone you made it yourself.
A really cool idea would be to make one out of a map from a certain trip, then get a charm that reminds you of the place you went and loop it through!
Jewelry Contest
Finalist in the
Jewelry Contest
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    15 Comments
    Great idea! Using up old sectional charts (used by pilot's for navigation) this way would be cool. You could have your base airport as the outer layer.
    This is a great idea, I made two bangles from a london underground map. I love the geometrical patterns and they're functional too. Thank you for this. x
    Thanks, and that's awesome!
    Love This! I have a bunch of old maps & now I know what to do with them.
    Great instructable, I liked the ring one, but think this would be more practical. Good work.
    thats pretty cool. you'll never get lost again. .lol who needs gps. nice instructable
    Nice, I like the idea to make it a memento from a trip.
