Recycled Materials Rubberband Shooter
Published
Introduction: Recycled Materials Rubberband Shooter
About: I've moved on to bigger and better projects! It was fun Instructables!
This one of the best rubberband guns ever!
It can shoot across the room a top speeds!
So try it out!
Made out of three recycled items...
Toilet Paper Roll, Wrapping Paper Scraps, And Old Pieces Of Paper.
Step 1: Step 1: Materials
Before you start you will need a few things like...
1. A Toilet Paper Roll
2. A Rubberband
3. Old Wrapping Paper Scraps
4. Scissors
5. A Hole Puncher.
6. Tape
Step 2: Step 2: Wrap It Up!
First you need to wrap up the toilet paper roll with your wrapping paper.
Then tape it on, punch holes on one side.
Next you punch holes across from your first hole.
Then you punch holes under each hole on the bottom.
Step 3: Step 3: the Rubberband
On this step you need to get your scissors and cut your rubberband.
Then stick it through both ends of one end of the toilet paper roll.
Next you stretch the rubberband all the way across the side and through the hole on the other end.
Tape it in there and do the same on the other side.
Step 4: Step 4: Ammo
Now you need some ammo.
Get a regular piece of paper and cut it down into a small square.
Keep folding until it can not be folded any more.
Step 5: Step 5: Loading Up Your Ammo
To load up your ammo you need to hook it on the rubberband and pull back!
Please comment!
    • Clocks Contest
      Clocks Contest
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    11 Comments
    To aim hold it like a machine gun.
    haha u dnt hav a comment so i will leave 1 i jus made a slingshot wit a rubber band tht probly works betr mine shots proly 50+ feet all i used was 2 pieces of wood and sum nails
    I'm not using wood.
    I  know that ur not usin wood im just sayin i used wood i modified it
    A slingshot made by someone who either doesn't know how to spell or can't be bothered to do so doesn't count as a modification unless it's a refinement of the idea in the original instructions.
    Cool We do things like this at school but we use only a ruberband, our fingers, and sompe paper for the ammo
    Cool!!! P.S. you use perry the platypus' face
