Recycled PVC Seven Segment Display
259
6
Posted
Introduction: Recycled PVC Seven Segment Display
i have been planning on making a digital clock i can hang on my wall for some time now but i kept putting it of because i just did not want to buy acrylic so i used some leftover PVC cable ducts and i have to say the results ar not that bed so lets get to it
Step 1: Material and Tools
the first thing your going to need is about 24 inches of PVC duct
28 leds
and some wires
the tools your going to need are
hot glue gun (and hot glue)
soldering iron (and solder)
hacksaw
and drill(and wood drill bits)
Step 2: Measure Once Cut Twice ;)
now its time to cut the PVC duct make sure your measurements are correct the first time around to save time
measure peaces if 4,5 inches (or 11.5mm if that's your preferred unit of measurement )
since your already measuring might as wall do the ones for the leds
the space i used for my leds is 1,5" (this includes the space between peaces)
if your going to buy the PVC ducts you can get them to cut it for you for free (well it depends if they offer that service
also don't forget to drill a whole on the side of the PVC duct to allow you to join the top middle and bottom leds together
Step 3: The Drilling
now comes the most repetitive part you have to drill 28 for the leds i used wood drill bits because iot has that pointy tip that stops it from moving around and ruining my accuracy
also if you want to cut you drilling time in half clamp one on top of the other (came of to that after i was done)
Step 4: Soldamo Iones
time to solder the leds together remember to prototype you don't want to be stuck with an led that dose not work
bend the leds solder them together test them to make sure they are put in that correct way polarity wise
Step 5: Hooking Up
since this is a common cathode setup solder all the cathodes together then add a wire to the anodes repeat this for all the digits
then for durability sake it is a goo idea to hot glue the leds in place and the digits together if you don't feel this will be good enough you can use PVC cement
and if you did eveything correct your end product will look like this
now that your done you can can use your arduino to control the display
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
That's a neat display :)
