You can use an iron to fuse together grocery bags into a thick sheet of plastic.
Then you can use that plastic to make a durable, waterproof, recycled, and stylish messenger bag or purse.
I've seen some great instructables on different variations of the fused plastic-bag, and I thought I'd share the process I've been using.
I'll show you a purse I'm making as a birthday present. To make a messenger bag, you follow the same process but make the dimensions a bit larger.
This is a great bag for the new school year!
You'll need:
- a lot of thin, plastic grocery bags
- a few patterned or colorful bags for decoration
- 1 large trash bag, for the strap
- a clothes iron (my iron recently died, so you'll notice I'm using an old-school iron that normally gets used as a doorstop. But a normal iron is just fine)
- aluminum foil or parchment paper, to keep the iron from sticking to the plastic
- scissors
- pins, or an extra pair of hands
- soldering iron (optional)
- velcro (optional)
- Some free time, patience, and good music
Remove these ads by
Signing UpStep 1Fusing the plastic
WARNING: If at any time you see smoke or smell any fumes coming from the plastic, Stop. You're doing it very wrong. You only want to heat the plastic enough so that the layers will fuse together, and as far as I know this will not release any fumes. However, as always, you should do this in a place with decent ventilation, just in case.
I like to work on the table or the kitchen counter, with a towel covering the surface. Ironing boards are annoying to use for this because they are so narrow.
Take 2 grocery bags and cut off the handles and the seam at the bottom, so you're left with a nice rectangle. Lay the bags flat on top of each other, and sandwich them between 2 sheets of aluminum foil or parchment paper (used for cooking).
IMPORTANT: Do not touch the iron directly to the plastic. It will melt and burn and smell bad and your iron will be nasty.
You'll have to play around with the heat settings depending on how thick your sheet of plastic, but for one bag, start out on a medium or low setting. When you press down the iron, you should hear a quiet crinkling sound as the plastic contracts and fuses. If you get a lacy pattern of melted holes, the iron is too hot.
If you're using parchment paper, which is translucent, it's easy to tell where the plastic has fused and stuck to the paper.
Start out with a light pressure and don't stay in one place for too long. Wait a couple seconds for it to cool before you lift up the foil/paper, so you won't rip the melty plastic. As your sheet of plastic gets thicker, you may need to increase the heat setting on the iron.
Don't leave any air bubbles or unfused spots, or your plastic will be weak! Make sure you keep flipping the plastic over and ironing it on both sides.
A pleasure to view; thanks!
Then there's this from http://www.seventhgeneration.com/it-harmful-burn-plastic-bags
Do NOT Burn plastic bags! It creates one of the most toxic chemicals known: DIOXIN. PLEASE be careful NOT to take plastic bags from stores. It's easy enough to start a habit of bringing your own organic bag (not one made of polypropelene- which is plastic that looks like cloth!). Plastic NEVER biodegrades - and even if it's made into something else, eventually, it will break apart and be thrown "away" - where is away??
And I know that burnt styrofoam makes cyanide, so its better to err on the side of caution.
When I used to design giftware using Sculpey, the original stuff, we burnt it then painted it. It made it harder.
Its more important to get that 15 minutes per quarter inch of thickness at the specified temp than to overcook it. It has to change its chemical composition, and it will only morph at 275 for 15 at that thickness. More time is necessary for thicker pieces, and if there's any thinner pieces attatched, there you go.
I wonder how many pvc molecules get transferred to the air and oven walls, but none of us will really know, will we. Until its too late. Wait, I can handle the hot stuff with my asbestos gloves! Word. I'd only do the plastic outside. I have a toaster oven for my sculpey. I put it on its own pan, on a polyester foam nest,
Glass Attic, polymer clay central, polymer clay anything, if you google polymer clay safety, there's all kinds of info. That's who "they" is, and I is they as well, now, isn't i?
