3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recycled Plastic Messenger Bag or Purse
Step 4Assembling the Bag
Assembling the Bag
Now that you have a nice, pretty sheet of plastic, it's time to fold it into a bag. Figure out your final dimensions and cut the plastic to the template below, so that it looks like an unfolded pastry box.
First you fold the plastic along one of those two horizontal, dotted lines in the middle of the sheet. Overlap the two tabs so that the plastic is folded at a right angle. It doesn't matter whether that little tab goes on the inside or the outside of the long tab. You just have to fuse the two tabs together. One easy way to do this is to place the tabs on the corner of a table or a countertop, as shown below, and then fuse them together. You should use the tip of the iron to fuse the inside (white side) of the seam as well.
The iron will have to be on a pretty high setting to heat this many layers of plastic. You need to securely fuse the layers together, but don't go overboard and melt/damage the thinner surrounding plastic!
Once you've fused both corners at right angles, it's on to the next step!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
73
Author:emattrose
