Step 5Assembling the Bag - Part 2
Ironing this seam is a bit trickier, but it's the same idea. Get somebody to give you a hand, or pin the two long tabs together. Put the bag on its side so that the overlapped tabs lie flat against the table, and carefully iron the inside (white side).
If you're having trouble reaching a spot with the iron, try using a soldering iron. Just be careful not to accidentally melt holes with the tip!
Remember to iron the outside of the seam as well. The best way to do this is to take a long piece of wood, like a two-by-four, and let the end of it stick off the edge of a table. Then you put the seam over the two-by-four, so you have something to press the iron against.
Add Comment
